jose2
January 22, 2018, 12:02am
#1
Hi! How are you!
I need help if someone knows “WHY”
I try to run
certbot renew --dry-run
And then i get this error
Detail: The key authorization file from the server did not match
this challenge
[GPPa6-K8-Q9zhoZz0xQOb6NCgj0egmx-3_6u7X2M.f2FPWFFGxII7ZWbQ4shR3KvlXZ0rawcw377ttutQ]
[GPPa6-K8-Q9zhoZz0xQOb6NCgj0egmx-3_6u7X.2DhyZoRZqxSfs2Y0qz9Gc72la44NbOKg-dTStVhq0]
Then i open
nano /home/admin/conf/web/domain.com.nginx.conf
And i added this
location ^~ /.well-known/acme-challenge/ {
default_type “text/plain”;
And now its working, i am using vestacp (fresh installation and i am using the domain as a vesta´s admin panel forcing to https)
_az
January 22, 2018, 12:10am
#2
The default_type
is most likely a red herring.
More likely:
Before: all requests were being routed to specific endpoint, e.g. index.php
After: due to the more specific location block, nginx falls back to regular behavior of serving files from document root.
Hard to say for sure without the full configuration.
jose2
January 22, 2018, 12:12am
#4
_az:
The default_type is most likely a red herring.
More likely:
Then now, it will work fine or i need renew manually each domain every 3 months?
system
closed
February 21, 2018, 12:12am
#5
