nrbrt
October 12, 2020, 5:36pm
21
out put of certbot certificates is:
Found the following certs:
Certificate Name: lavaleriana.net
Domains: *.lavaleriana.net *.bb-stilltech.nl *.scotspine.nl bb-stilltech.nl lavaleriana.net scotspine.nl
Expiry Date: 2020-10-11 10:09:38+00:00 (INVALID: EXPIRED)
Certificate Path: /etc/letsencrypt/live/lavaleriana.net/fullchain.pem
Private Key Path: /etc/letsencrypt/live/lavaleriana.net/privkey.pem
rg305
October 12, 2020, 5:38pm
22
hmm...
Please show:
ls -la /etc/letsencrypt/live/
nrbrt
October 12, 2020, 5:41pm
23
total 16
drwx------ 3 root root 4096 Oct 9 10:41 .
drwxr-xr-x 9 root root 4096 Oct 12 19:36 ..
-rw-r--r-- 1 root root 740 Nov 11 2019 README
lrwxrwxrwx 1 root root 42 Oct 11 14:50 lavaleriana.net -> /etc/letsencrypt/live/lavaleriana.net-0002
drwxr-xr-x 2 root root 4096 Jul 13 13:09 lavaleriana.net-0002
rg305
October 12, 2020, 5:44pm
24
That seems kind of weird...
Please show:
ls -la /etc/letsencrypt/live/lavaleriana.net-0002/
nrbrt
October 12, 2020, 5:45pm
25
total 12
drwxr-xr-x 2 root root 4096 Jul 13 13:09 .
drwx------ 3 root root 4096 Oct 9 10:41 ..
-rw-r--r-- 1 root root 692 Jul 13 13:04 README
lrwxrwxrwx 1 root root 44 Oct 11 14:50 cert.pem -> ../../archive/lavaleriana.net-0002/cert2.pem
lrwxrwxrwx 1 root root 45 Oct 11 14:50 chain.pem -> ../../archive/lavaleriana.net-0002/chain2.pem
lrwxrwxrwx 1 root root 49 Oct 11 14:50 fullchain.pem -> ../../archive/lavaleriana.net-0002/fullchain2.pem
lrwxrwxrwx 1 root root 47 Oct 11 14:50 privkey.pem -> ../../archive/lavaleriana.net-0002/privkey2.pem
rg305
October 12, 2020, 5:48pm
26
And yet:
Freshly issued certs ? ? ?
Your links are messing up the process.
I don't know how it got like that but we need to fix them or this will continue.
Try:
certbot update_symlinks
rg305
October 12, 2020, 5:51pm
27
Just curious...
Please show:
ls -la /etc/letsencrypt/live/lavaleriana.net/
And
cat /etc/letsencrypt/renewal/lavaleriana.net.conf
nrbrt
28
/var/log/letsecrypt/letsencrypt.log:
2020-10-12 19:49:26,602:DEBUG:certbot.main:certbot version: 0.40.1
2020-10-12 19:49:26,605:DEBUG:certbot.main:Arguments: []
2020-10-12 19:49:26,606:DEBUG:certbot.main:Discovered plugins: PluginsRegistry(PluginEntryPoint#dns-cloudflare,PluginEntryPoint#manual,PluginEntryPoint#null,PluginEntryPoint#standalone,PluginEntryPoint#webroot)
2020-10-12 19:49:26,619:DEBUG:certbot.log:Root logging level set at 20
2020-10-12 19:49:26,620:INFO:certbot.log:Saving debug log to /var/log/letsencrypt/letsencrypt.log
should I try renewing again?
rg305
October 12, 2020, 5:53pm
30
Please show:
and
nrbrt
October 12, 2020, 5:55pm
31
root@omega-r2:~# ls -la /etc/letsencrypt/live/lavaleriana.net-0002/
total 12
drwxr-xr-x 2 root root 4096 Oct 12 19:49 .
lrwxrwxrwx 1 root root 39 Oct 12 19:49 cert.pem -> ../../archive/lavaleriana.net/cert2.pem
lrwxrwxrwx 1 root root 40 Oct 12 19:49 chain.pem -> ../../archive/lavaleriana.net/chain2.pem
lrwxrwxrwx 1 root root 44 Oct 12 19:49 fullchain.pem -> ../../archive/lavaleriana.net/fullchain2.pem
lrwxrwxrwx 1 root root 42 Oct 12 19:49 privkey.pem -> ../../archive/lavaleriana.net/privkey2.pem
root@omega-r2:~# ls -la /etc/letsencrypt/live/lavaleriana.net/
total 12
root@omega-r2:~# cat /etc/letsencrypt/renewal/lavaleriana.net.conf
version = 0.40.1
archive_dir = /etc/letsencrypt/archive/lavaleriana.net
cert = /etc/letsencrypt/live/lavaleriana.net/cert.pem
privkey = /etc/letsencrypt/live/lavaleriana.net/privkey.pem
chain = /etc/letsencrypt/live/lavaleriana.net/chain.pem
fullchain = /etc/letsencrypt/live/lavaleriana.net/fullchain.pem
[renewalparams]
dns_cloudflare_credentials = /root/.secrets/cloudflare.ini
authenticator = dns-cloudflare
pref_challs = dns-01,
account = ac1a5331297eafb85c42af82970f1136
post_hook = /usr/sbin/service apache2 reload
rg305
October 12, 2020, 6:04pm
32
That seems like it should work.
I wonder if you have multiple versions of certbot installed...?
Please show:
certbot --version
which certbot
find / -name certbot
nrbrt
October 12, 2020, 6:11pm
33
root@omega-r2:~# certbot --version
certbot 0.40.1
root@omega-r2:~# which certbot
/usr/local/bin/certbot
root@omega-r2:~# find / -xdev -name certbot
/etc/cron.d/certbot
/etc/logrotate.d/certbot
/snap/bin/certbot
/snap/certbot
/root/snap/certbot
/var/snap/certbot
/usr/local/lib/python3.5/dist-packages/certbot
/usr/lib/python2.7/dist-packages/certbot
/usr/lib/python3/dist-packages/certbot
/usr/bin/certbot
rg305
October 12, 2020, 6:12pm
34
Please show:
/snap/bin/certbot --version
/usr/bin/certbot --version
nrbrt
35
root@omega-r2:~# /snap/bin/certbot --version
certbot 1.9.0
nrbrt
October 12, 2020, 6:13pm
36
root@omega-r2:~# /usr/bin/certbot --version
certbot 1.9.0
rg305
37
Then the snap is the one you should be using.
[1.9.0 is much higher then 0.40.1]
You can remove the other one from apt.
sudo apt remove certbot
Then show:
which certbot
nrbrt
October 12, 2020, 6:16pm
38
root@omega-r2:~# /usr/local/bin/certbot --version
certbot 0.40.1
rg305
October 12, 2020, 6:17pm
39
rg305:
and also show:
ls -l /lib/systemd/system/certbot*
nrbrt
October 12, 2020, 6:18pm
40
root@omega-r2:~# sudo apt remove certbot
Reading package lists... Done
Building dependency tree
Reading state information... Done
Package 'certbot' is not installed, so not removed
The following packages were automatically installed and are no longer required:
libicu64 linux-image-4.9.0-11-amd64 linux-image-4.9.0-9-amd64 python3-acme python3-augeas python3-certbot python3-configargparse python3-configobj python3-future python3-josepy python3-mock
python3-parsedatetime python3-pbr python3-requests-toolbelt python3-rfc3339 python3-tz python3-zope.component python3-zope.event python3-zope.hookable python3-zope.interface
Use 'sudo apt autoremove' to remove them.
0 upgraded, 0 newly installed, 0 to remove and 5 not upgraded.
Should I just rm /usr/local/bin/certbot?
