A (document) root path within the location /.well-known/acme-challenge
Hi, Mr. rg305,
I might not fully understand what I should do, but I chenged a-trust.ibcc.fun.conf as below.
<virtualhost *:443>
ServerName a-trust.ibcc.fun
# this path is unuseful and used only for Let's Encrypt's temporary files during the renewal process
DocumentRoot /var/www/html
# send all traffic to Icecast in plaintext
<Location "/">
ProxyPass http://localhost:8000/
ProxyPassReverse http://localhost:8000/
</Location>
# these files are served from /var/www/html to serve Let's Encrypt temporary files
<Location "/.well-known/acme-challenge">
ProxyPass https://localhost:8000/
ProxyPassReverse https://localhost:8000/
ProxyPass https://localhost:443/
ProxyPassReverse https://localhost:443/
# ProxyPass !
</Location>
<IfFile /etc/letsencrypt/live/a-trust.ibcc.fun/cert.pem>
SSLEngine on
SSLCertificateFile /etc/letsencrypt/live/a-trust.ibcc.fun/cert.pem
SSLCertificateKeyFile /etc/letsencrypt/live/a-trust.ibcc.fun/privkey.pem
SSLCertificateChainFile /etc/letsencrypt/live/a-trust.ibcc.fun/chain.pem
</IfFile>
</virtualhost>
<VirtualHost *:80>
Redirect / https://a-trust.ibcc.fun/
</VirtualHost>
and restarted the server.
and, I got the same result as before,
root@157-7-207-219:~# letsencrypt certonly --domain a-trust.ibcc.fun --webroot --webroot-path /var/www/html
Requesting a certificate for a-trust.ibcc.fun
http-01 challenge for a-trust.ibcc.fun
Using the webroot path /var/www/html for all unmatched domains.
Challenge failed for domain a-trust.ibcc.fun
Domain: a-trust.ibcc.fun
Type: connection
Detail: 157.7.207.219: Fetching
https://a-trust.ibcc.fun/.well-known/acme-challenge/KhkSB5z1OdnJJsb5_IXbonHgl7PX1CZMtjNHfH3OxzQ:
Error getting validation data
If I made wrong change on the file, a-trust.ibdd.fun.conf .
please let me know in detail.
Thank you.
Shee
That looks correct.
But with Apache
what you see isn't always what you get.
Try placing a file in the expected challenge location:
/var/www/html/.well-known/acme-challenge/test-file-name
Then see if it can be reached via the Internet:
http://a-trust.ibcc.fun/.well-known/acme-challenge/test-file-name
I must have missed it earlier
The document root was there all along.
You cannot have it both ways. Either:
- You have
SSLEngine On
always, and use a snakeoil certificate as a fallback if the Let's Encrypt certificate does not exist, or - You answer the ACME challenge on port 80 without redirecting to HTTPS.
I think the latter option is probably simpler, you can do something like:
<VirtualHost *:80>
RewriteEngine On
RewriteCond "%{REQUEST_URI}" "!^/\.well-known/acme-challenge/"
RewriteRule ^(.*)$ https://a-trust.ibcc.fun$1 [R]
</VirtualHost>
Once your HTTPS virtualhost is actually HTTPS-enabled, then you can go back how you had it to before, if you want.
Hi Mr. rg305 & _az,
Thank you very much for your perseverance.
I changed last part of a-trust.ibcc.fun.conf as Mr. _az showed.
But I don't understand in deep, so I tried as the sentence is, and again I did it with changing "REQUEST_URL" to "a-trust.ibcc.fun".
but the result were the completely asme as below.
Type: connection
http://a-trust.ibcc.fun/.well-known/acme-challenge/JiEhsBk5HvpVIIHEPhigz6BqaKuPGaCpc959bjK0RQc:
Connection refused
give me advice, or tell me if I misunderstood.
Thank you.
Shee
Port 80 is not reachable.
curl -Ii http://a-trust.ibcc.fun/
I don't understand deep part of this area, but what I want to do is to connect audio stream with https so, do you think is it mean-full to change port number of the stream from 8000 to 443 at Icecast server setting?
One thing at a time.
First get the cert.
Hi Mr.rg305
there seems to be something invisible. I can't open it. It may not related,,,,
root@157-7-207-219:/var/www/html/.well-known/acme-challenge# ls -al .*
total 8
drwxrwxrwx 2 root root 4096 Apr 15 15:13 .
drwxr-xr-x 3 root root 4096 Apr 10 22:59 ..
total 12
drwxr-xr-x 3 root root 4096 Apr 10 22:58 ..
drwxrwxrwx 2 root root 4096 Apr 15 15:13 acme-challenge
root@157-7-207-219:/var/www/html/.well-known/acme-challenge# cd acme-challenge
-bash: cd: acme-challenge: No such file or directory
acme-challenge under acme-challenge
is it the directly itself?
It doesn't look like Apache is running at all.
Check that the config is OK:
apachectl -t
and try restart Apache:
systemctl restart apache2
ether commands were not accepted
the server used to answer request for icecast admin page, but now it won't.
root@157-7-207-219:~# apacheclt -t
-bash: apacheclt: command not found
root@157-7-207-219:~# systemclt restart apache2
-bash: systemclt: command not found
root@157-7-207-219:~# service apache2 restart
Job for apache2.service failed because the control process exited with error code.
See "systemctl status apache2.service" and "journalctl -xe" for details.
I don't know how to read this.
root@157-7-207-219:~# journalctl -xe
░░ Subject: Unit process exited
░░ Defined-By: systemd
░░ Support: https://www.debian.org/support
░░ An ExecStart= process belonging to unit apache2.service has exited.
░░ The process' exit code is 'exited' and its exit status is 1.
Apr 15 16:57:39 157-7-207-219 systemd[1]: apache2.service: Failed with result 'exit-code'.
░░ Subject: Unit failed
░░ The unit apache2.service has entered the 'failed' state with result 'exit-code'.
Apr 15 16:57:39 157-7-207-219 systemd[1]: Failed to start The Apache HTTP Server.
░░ Subject: A start job for unit apache2.service has failed
░░ A start job for unit apache2.service has finished with a failure.
░░ The job identifier is 350 and the job result is failed.
Apr 15 16:57:43 157-7-207-219 sshd[1449]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh>
Apr 15 16:57:45 157-7-207-219 sshd[1449]: Failed password for root from 61.177.173.58 port 64650 ssh2
Apr 15 16:57:47 157-7-207-219 sshd[1449]: Failed password for root from 61.177.173.58 port 64650 ssh2
Apr 15 16:57:51 157-7-207-219 sshd[1449]: Failed password for root from 61.177.173.58 port 64650 ssh2
Apr 15 16:57:52 157-7-207-219 sshd[1449]: Received disconnect from 61.177.173.58 port 64650:11: [preauth]
Apr 15 16:57:52 157-7-207-219 sshd[1449]: Disconnected from authenticating user root 61.177.173.58 port 64650 [preau>
Apr 15 16:57:52 157-7-207-219 sshd[1449]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= r>
Apr 15 16:58:05 157-7-207-219 sshd[1451]: Invalid user user from 213.74.115.162 port 40970
Apr 15 16:58:05 157-7-207-219 sshd[1451]: pam_unix(sshd:auth): check pass; user unknown
Apr 15 16:58:05 157-7-207-219 sshd[1451]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh>
Apr 15 16:58:07 157-7-207-219 sshd[1451]: Failed password for invalid user user from 213.74.115.162 port 40970 ssh2
Apr 15 16:58:09 157-7-207-219 sshd[1451]: Received disconnect from 213.74.115.162 port 40970:11: Bye Bye [preauth]
Apr 15 16:58:09 157-7-207-219 sshd[1451]: Disconnected from invalid user user 213.74.115.162 port 40970 [preauth]
Apr 15 16:58:20 157-7-207-219 sshd[1453]: Connection closed by 167.94.146.57 port 44868 [preauth]
Apr 15 16:58:35 157-7-207-219 sshd[1456]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh>
Apr 15 16:58:37 157-7-207-219 sshd[1456]: Failed password for root from 61.177.173.58 port 25421 ssh2
Apr 15 16:58:40 157-7-207-219 sshd[1456]: Failed password for root from 61.177.173.58 port 25421 ssh2
Apr 15 16:58:40 157-7-207-219 sshd[1458]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh>
Apr 15 16:58:42 157-7-207-219 sshd[1458]: Failed password for root from 43.156.238.161 port 59128 ssh2
Apr 15 16:58:42 157-7-207-219 sshd[1460]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh>
Apr 15 16:58:43 157-7-207-219 sshd[1462]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh>
Apr 15 16:58:44 157-7-207-219 sshd[1458]: Received disconnect from 43.156.238.161 port 59128:11: Bye Bye [preauth]
Apr 15 16:58:44 157-7-207-219 sshd[1458]: Disconnected from authenticating user root 43.156.238.161 port 59128 [prea>
Apr 15 16:58:44 157-7-207-219 sshd[1460]: Failed password for root from 41.72.219.102 port 36032 ssh2
Apr 15 16:58:44 157-7-207-219 sshd[1462]: Failed password for root from 43.153.103.80 port 35396 ssh2
Apr 15 16:58:45 157-7-207-219 sshd[1460]: Received disconnect from 41.72.219.102 port 36032:11: Bye Bye [preauth]
Apr 15 16:58:45 157-7-207-219 sshd[1460]: Disconnected from authenticating user root 41.72.219.102 port 36032 [preau>
Apr 15 16:58:45 157-7-207-219 sshd[1462]: Received disconnect from 43.153.103.80 port 35396:11: Bye Bye [preauth]
Apr 15 16:58:45 157-7-207-219 sshd[1462]: Disconnected from authenticating user root 43.153.103.80 port 35396 [preau>
Apr 15 16:58:46 157-7-207-219 sshd[1456]: Failed password for root from 61.177.173.58 port 25421 ssh2
Apr 15 16:58:51 157-7-207-219 sshd[1464]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh>
Apr 15 16:58:53 157-7-207-219 sshd[1464]: Failed password for root from 84.53.228.192 port 37772 ssh2
Apr 15 16:58:56 157-7-207-219 sshd[1464]: Received disconnect from 84.53.228.192 port 37772:11: Bye Bye [preauth]
Apr 15 16:58:56 157-7-207-219 sshd[1464]: Disconnected from authenticating user root 84.53.228.192 port 37772 [preau>
Apr 15 16:59:17 157-7-207-219 sshd[1467]: Invalid user user from 213.74.115.162 port 41788
Apr 15 16:59:17 157-7-207-219 sshd[1467]: pam_unix(sshd:auth): check pass; user unknown
Apr 15 16:59:17 157-7-207-219 sshd[1467]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh>
Apr 15 16:59:20 157-7-207-219 sshd[1467]: Failed password for invalid user user from 213.74.115.162 port 41788 ssh2
Apr 15 16:59:21 157-7-207-219 sshd[1467]: Received disconnect from 213.74.115.162 port 41788:11: Bye Bye [preauth]
Apr 15 16:59:21 157-7-207-219 sshd[1467]: Disconnected from invalid user user 213.74.115.162 port 41788 [preauth]
Apr 15 16:59:32 157-7-207-219 sshd[1469]: Invalid user first from 8.37.43.159 port 43218
Apr 15 16:59:32 157-7-207-219 sshd[1469]: pam_unix(sshd:auth): check pass; user unknown
Apr 15 16:59:32 157-7-207-219 sshd[1469]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh>
Apr 15 16:59:33 157-7-207-219 sshd[1469]: Failed password for invalid user first from 8.37.43.159 port 43218 ssh2
Apr 15 16:59:34 157-7-207-219 sshd[1469]: Received disconnect from 8.37.43.159 port 43218:11: Bye Bye [preauth]
Apr 15 16:59:34 157-7-207-219 sshd[1469]: Disconnected from invalid user first 8.37.43.159 port 43218 [preauth]
Apr 15 16:59:40 157-7-207-219 sshd[1471]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh>
Apr 15 16:59:42 157-7-207-219 sshd[1471]: Failed password for root from 61.177.173.58 port 32970 ssh2
Apr 15 16:59:46 157-7-207-219 sshd[1471]: Failed password for root from 61.177.173.58 port 32970 ssh2
Apr 15 16:59:49 157-7-207-219 sshd[1473]: Invalid user user from 43.153.103.80 port 58344
Apr 15 16:59:49 157-7-207-219 sshd[1473]: pam_unix(sshd:auth): check pass; user unknown
Apr 15 16:59:49 157-7-207-219 sshd[1473]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh>
Apr 15 16:59:49 157-7-207-219 sshd[1471]: Failed password for root from 61.177.173.58 port 32970 ssh2
Apr 15 16:59:51 157-7-207-219 sshd[1473]: Failed password for invalid user user from 43.153.103.80 port 58344 ssh2
Apr 15 16:59:52 157-7-207-219 sshd[1473]: Received disconnect from 43.153.103.80 port 58344:11: Bye Bye [preauth]
Apr 15 16:59:52 157-7-207-219 sshd[1473]: Disconnected from invalid user user 43.153.103.80 port 58344 [preauth]
Apr 15 16:59:55 157-7-207-219 sshd[1471]: Received disconnect from 61.177.173.58 port 32970:11: [preauth]
Apr 15 16:59:55 157-7-207-219 sshd[1471]: Disconnected from authenticating user root 61.177.173.58 port 32970 [preau>
Apr 15 16:59:55 157-7-207-219 sshd[1471]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= r>
Apr 15 17:00:01 157-7-207-219 sshd[1475]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh>
Apr 15 17:00:03 157-7-207-219 sshd[1475]: Failed password for root from 61.177.173.58 port 62835 ssh2
Apr 15 17:00:04 157-7-207-219 sshd[1477]: Invalid user zabbix from 165.232.113.128 port 57070
Apr 15 17:00:05 157-7-207-219 sshd[1477]: pam_unix(sshd:auth): check pass; user unknown
Apr 15 17:00:05 157-7-207-219 sshd[1477]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh>
Apr 15 17:00:07 157-7-207-219 sshd[1477]: Failed password for invalid user zabbix from 165.232.113.128 port 57070 ss>
Apr 15 17:00:07 157-7-207-219 sshd[1479]: Invalid user admin from 84.53.228.192 port 36238
Apr 15 17:00:07 157-7-207-219 sshd[1479]: pam_unix(sshd:auth): check pass; user unknown
Apr 15 17:00:07 157-7-207-219 sshd[1479]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh>
Apr 15 17:00:08 157-7-207-219 sshd[1477]: Connection closed by invalid user zabbix 165.232.113.128 port 57070 [preau>
Apr 15 17:00:09 157-7-207-219 sshd[1475]: Failed password for root from 61.177.173.58 port 62835 ssh2
Apr 15 17:00:09 157-7-207-219 sshd[1479]: Failed password for invalid user admin from 84.53.228.192 port 36238 ssh2
Apr 15 17:00:11 157-7-207-219 sshd[1475]: Received disconnect from 61.177.173.58 port 62835:11: [preauth]
Apr 15 17:00:11 157-7-207-219 sshd[1475]: Disconnected from authenticating user root 61.177.173.58 port 62835 [preau>
Apr 15 17:00:11 157-7-207-219 sshd[1475]: PAM 1 more authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rh>
Apr 15 17:00:11 157-7-207-219 sshd[1479]: Received disconnect from 84.53.228.192 port 36238:11: Bye Bye [preauth]
Apr 15 17:00:11 157-7-207-219 sshd[1479]: Disconnected from invalid user admin 84.53.228.192 port 36238 [preauth]
Apr 15 17:00:13 157-7-207-219 sshd[1481]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh>
Apr 15 17:00:15 157-7-207-219 sshd[1481]: Failed password for root from 20.204.65.175 port 6080 ssh2
Apr 15 17:00:16 157-7-207-219 sshd[1481]: Received disconnect from 20.204.65.175 port 6080:11: Bye Bye [preauth]
Apr 15 17:00:16 157-7-207-219 sshd[1481]: Disconnected from authenticating user root 20.204.65.175 port 6080 [preaut>
Apr 15 17:00:28 157-7-207-219 sshd[1483]: Invalid user user from 213.74.115.162 port 46310
Apr 15 17:00:28 157-7-207-219 sshd[1483]: pam_unix(sshd:auth): check pass; user unknown
Apr 15 17:00:28 157-7-207-219 sshd[1483]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh>
Apr 15 17:00:30 157-7-207-219 sshd[1483]: Failed password for invalid user user from 213.74.115.162 port 46310 ssh2
lines 1017-1121/1121 (END)
Shall I restart the server?
I checked. please see the board.
I restart the server and test it again, but the results are the same.
root@157-7-207-219:~# apachectl -t
AH00526: Syntax error on line 35 of /etc/apache2/sites-enabled/a-trust.ibcc.fun.conf:
Invalid command 'RewriteEngine', perhaps misspelled or defined by a module not included in the server configuration
Action '-t' failed.
day before yesterday? several days ago, apache had been working, I saw icecast admin page then.
Mr. _az
I think after I added some sentences in a-trst.ibcc.fun.conf, apache2 had stopped.
I might misunderstood, but adding the lines below, syntax error had started. now I deleted those lines and aoache2 have been running.
<VirtualHost *:80>
RewriteEngine On
</VirtualHost>
I don' know this situation, but it seems to go through.
Can I think this mean "get it"?
root@157-7-207-219:/usr/share/icecast2# letsencrypt certonly --domain a-trust.ibcc.fun --webroot --webroot-path /var/www/html
Subscribe to the EFF mailing list (email: shigeru@artech.jp).
/etc/letsencrypt/live/a-trust.ibcc.fun/fullchain.pem
Your certificate will expire on 2023-07-14. To obtain a new or
tweaked version of this certificate in the future, simply run
certbot again. To non-interactively renew *all* of your
certificates, run "certbot renew"
Donating to ISRG / Let's Encrypt: https://letsencrypt.org/donate
Hi Guys,
I received key and certificates regarding one server, a-trust.ibcc.fun.
While apache had been stopped, I made some changes and when apache was started I found it was fixed, so finally I could not understand what's wrong.
Although I checked all configuration files, I couldn't find any difference between files of two servers, but server for kbc.ibcc.fun could not get certificates yet.
But I did finished one with your supports, so regarding the other one, I should do by myself.
Thank you for helping me.
I won't forget your supports.
Thank you very much.
so please close this topic.
Shee for Shigeru
