that is the path where the files of that domain or vhost are hosted
Not sure about LiteSpeed, but Apache tends to allow things even when they are rather messed up.
Is there any way to show the equivalent of:
sudo apachectl -t -D DUMP_VHOSTS
OR
sudo apachectl -S
If that really is the case, please put a test file in the appropriate directory path:
mkdir -p /home/labodademismejoresamigos.info/public_html/.well-known/acme-challenge
echo "testing one two three" > /home/labodademismejoresamigos.info/public_html/.well-known/acme-challenge/testfile
With the test file in place it should be able to view it at http://labodademismejoresamigos.info/.well-known/acme-challenge/testfile
[root@centwebpanel201 public_html]# sudo apachectl -t -D DUMP_VHOSTS
sudo: apachectl: command not found
[root@centwebpanel201 public_html]# sudo apachectl -S
You can check it yourself, load the file, it was necessary to assign permissions but that's it
What kind of permissions? Maybe Litespeed has some kind of permission behaviour not compatible with certbot too.
You can try to add --debug-challenges to the command line options of your certbot command. That will pause certbot when it has added the challenge token to your webroot path. During that pause, you can inspect the token files within the /acme-challenge/ directory (the same as where you put the test file earlier) with ls -l * or equivalent. Please cross-reference the token files permissions with the permissions required for proper serving of the files in Litespeed. Are the token permissions the same as the (incorrect) permissions of the test file before you changed those permissions? Can you issue a certificate if you manually correct the permissions of the token files?
echo "testing one two three" > /home/labodademismejoresamigos.info/public_html/.well-known/acme-challenge/testfile 177 / 5000 --> that when executing this command everything was created but from the outside I did not have permissions to access and it was not displayed, I had to add additional permissions by hand
Regarding the rest that you have told me ... excuse my ignorance but I do not understand you, I have taken the entire public_html folder and I have assigned 777 permissions, then I wanted to understand that you mean to execute the following command: sudo certbot certonly -d labodademismejoresamigos.info -d www.labodademismejoresamigos.info --debug-challenges / acme-challenge / ls -l *
which keeps giving me an error, please I am very new in this world, if you tell me command after command I will execute it, or I even give you root access in case you want to take a look and see it faster, since I am a bit stupid currently in this world
looking closely, I just saw that inside /home/labodademismejoresamigos.info/
There is a folder called ssl and a folder called certs and another called key
That was probably not a good idea.
I don't understand this part of your post.. I did not tell you to run those things as a single command?
when you were referring to this: -debug-challenges / acme-challenge / ls -l *
Can you tell me the complete command?
I'm not very fond of just handing out commands for people to run without them understanding what they're actually doing. I also think it's not that hard if you just chop up my post in the separate parts:
I assume you do know how to use the commands cd to get to a specific directory and use the command ls?
[root@centwebpanel201 ssl]# sudo certbot certonly -d labodademismejoresamigos.info -d www.labodademismejoresamigos.info --dry-run --debug-challenges
1: Spin up a temporary webserver (standalone)
2: Place files in webroot directory (webroot)
Starting new HTTPS connection (1): acme-staging-v02.api.letsencrypt.org
Simulating a certificate request for labodademismejoresamigos.info and www.labodademismejoresamigos.info
http-01 challenge for labodademismejoresamigos.info
http-01 challenge for www.labodademismejoresamigos.info
Input the webroot for labodademismejoresamigos.info: (Enter 'c' to cancel): /home/labodademismejoreamigos.info/public_html
/home/labodademismejoreamigos.info/public_html does not exist or is not a
directory
Input the webroot for labodademismejoresamigos.info: (Enter 'c' to cancel): /home/labodademismejoresamigos.info/public_html/
Select the webroot for www.labodademismejoresamigos.info:
1: Enter a new webroot
2: /home/labodademismejoresamigos.info/public_html
Challenges loaded. Press continue to submit to CA. Pass "-v" for more info about
challenges.
Press Enter to Continue
Challenge failed for domain www.labodademismejoresamigos.info
Challenge failed for domain labodademismejoresamigos.info
Domain: www.labodademismejoresamigos.info
Detail: Invalid response from
http://www.labodademismejoresamigos.info/.well-known/acme-challenge/YUwX571KJ7RG-jZUIbpvYZQcfn3lM-5fPSFG6bJageA
[176.56.119.157]: "\n<html
style="height:100%">\n\n<meta name="viewport"
content="width=device-width, initial-scale=1, shrink-to-"Domain: labodademismejoresamigos.info
http://labodademismejoresamigos.info/.well-known/acme-challenge/E39KTBHXCsab7fJ4LFMUwALmaotfHid4ZfmHAYPFaEY
content="width=device-width, initial-scale=1, shrink-to-"To fix these errors, please make sure that your domain name was
Did you immediately press "Enter" at that point or did you do what I asked you to do earlier?
I have verified that inside /home/labodademismejoresamigos.info/public_html/.well-known/acme-challenge creates 2 files with 0640 permissions both, but gives the error and the files disappear
Earlier, you said this about the test file (http://labodademismejoresamigos.info/.well-known/acme-challenge/testfile):
What specific permission change did you need to make before the test file worked?
Also, it could have been helpful to see the actual ls -l output of the challenge files. Maybe Litespeed needs specific permissions or specific ownership of the files.
Good morning, Before I had 0660 permissions, and it could not be accessed before changing to 777 permissions, but without making that change it showed the 404 error screen, however if I put 0664 if it loads the web
664 is better than 777
644 might be even better...
I'm not saying no ... but with 0777 we know that it is not a permission failure
Did 664 work like 777 ?
If so, try with 644.
with 0664 it works fine, now we have to see why it doesn't work ...
