Error, can not get domain token entry oichman.duckdns.org for tls-alpn-01
oichman.duckdns.org
"/root/.acme.sh"/acme.sh --cron --home "/root/.acme.sh"
[Mon Aug 1 09:58:26 IDT 2022] ===Starting cron===
[Mon Aug 1 09:58:26 IDT 2022] Renew: 'grafana.oichman.duckdns.org'
[Mon Aug 1 09:58:26 IDT 2022] Renew to Le_API=https://acme.zerossl.com/v2/DV90
[Mon Aug 1 09:58:26 IDT 2022] Skip invalid cert for: grafana.oichman.duckdns.org
[Mon Aug 1 09:58:26 IDT 2022] Skipped grafana.oichman.duckdns.org
[Mon Aug 1 09:58:27 IDT 2022] Renew: '*.oichman.duckdns.org'
[Mon Aug 1 09:58:27 IDT 2022] Renew to Le_API=https://acme.zerossl.com/v2/DV90
[Mon Aug 1 09:58:27 IDT 2022] Skip invalid cert for: *.oichman.duckdns.org
[Mon Aug 1 09:58:27 IDT 2022] Skipped *.oichman.duckdns.org
[Mon Aug 1 09:58:27 IDT 2022] Renew: 'oichman.duckdns.org'
[Mon Aug 1 09:58:43 IDT 2022] Using CA: https://acme.zerossl.com/v2/DV90
[Mon Aug 1 09:58:43 IDT 2022] Standalone alpn mode.
[Mon Aug 1 09:58:44 IDT 2022] Single domain='oichman.duckdns.org'
[Mon Aug 1 09:58:44 IDT 2022] Getting domain auth token for each domain
[Mon Aug 1 09:59:23 IDT 2022] Getting webroot for domain='oichman.duckdns.org'
[Mon Aug 1 09:59:24 IDT 2022] Error, can not get domain token entry oichman.duckdns.org for tls-alpn-01
[Mon Aug 1 09:59:24 IDT 2022] The supported validation types are: http-01 dns-01 , but you specified: tls-alpn-01
[Mon Aug 1 09:59:24 IDT 2022] Please add '--debug' or '--log' to check more details.
[Mon Aug 1 09:59:24 IDT 2022] See: How to debug acme.sh · acmesh-official/acme.sh Wiki · GitHub
[Mon Aug 1 09:59:24 IDT 2022] Error renew oichman.duckdns.org.
[Mon Aug 1 09:59:24 IDT 2022] ===End cron===
Linux (Debian)
Yes
It's possible that ZeroSSL doesn't support TLS-ALPN, I'm not sure.
You can try switch acme.sh over to Let's Encrypt and try again:
acme.sh --set-default-ca --server letsencrypt
or just pass the --server flag to your renew command.
Hi ,
still the same error :
[Mon Aug 1 14:03:36 IDT 2022] Error, can not get domain token entry oichman.duckdns.org for tls-alpn-01
[Mon Aug 1 14:03:36 IDT 2022] The supported validation types are: http-01 dns-01 , but you specified: tls-alpn-01
[Mon Aug 1 14:03:36 IDT 2022] Please add '--debug' or '--log' to check more details.
[Mon Aug 1 14:03:36 IDT 2022] See: How to debug acme.sh · acmesh-official/acme.sh Wiki · GitHub
[Mon Aug 1 14:03:36 IDT 2022] Error renew oichman.duckdns.org.
[Mon Aug 1 14:03:36 IDT 2022] ===End cron===
"/root/.acme.sh"/acme.sh --set-default-ca --server letsencrypt --cron --home "/root/.acme.sh"
Hi.
thank you very much , I solved it by reissuing the certificate , now everything is in order
thanks you very much for all your help
