Error by create cert with apache2 for Reverse Proxy
Hallo to the Forum,
i will use an Apache2 Server as an Reverse Proxy for my Exchange Server.
After i make the Apache Config, i will create an LE Cert.
Subdoamin: srv.domain.de -> static IP 80.xxx.xxx.xxx
A-Record: srv.domain.de
AAAA-Record -> Hoster
EX-Server: 192.xxx.xxx.xx
In the Apache2-Config:
Create Zert: certbot --apache
It shows me:
1: srv.domain.de
I take "1". Then it shows me:
Challenge failed for domain srv.domain.de
http-01 challenge for srv.domain.de
PLEASE, HELP ME. Whats wrong?
Many thanks.
Frank
This:
Are you sure that's the right IP address?
Have you checked any firewalls that might be in the way?
Have you checked your webserver on that machine, and its configuration? On port 80?
It is hard to help, when you don't show the true domain name.
Let's try answering all the questions you should have been shown:
