Olá bom dia
Pessoal,
Se poderem me auxiliar com um erro que estou tentando resolver.
Estou tentando subir o serviço apache porem da o seguinte erro.
root@des002 logs]# tail -f d1_error_log
[Mon Jan 11 19:35:22.795921 2021] [ssl:emerg] [pid 14537] SSL Library Error: error:0B080074:x509 certificate routines:X509_check_private_key:key values mismatch
[Mon Jan 11 20:01:47.835519 2021] [ssl:warn] [pid 15971] AH01909: RSA certificate configured for d1-fly.turby.com.br:443 does NOT include an ID which matches the server name
[Mon Jan 11 20:01:47.835591 2021] [ssl:emerg] [pid 15971] AH02238: Unable to configure RSA server private key
[Mon Jan 11 20:01:47.835624 2021] [ssl:emerg] [pid 15971] SSL Library Error: error:0B080074:x509 certificate routines:X509_check_private_key:key values mismatch
[Mon Jan 11 20:13:28.477481 2021] [ssl:warn] [pid 16588] AH01909: RSA certificate configured for d1-fly.turby.com.br:443 does NOT include an ID which matches the server name
[Mon Jan 11 20:13:28.477527 2021] [ssl:emerg] [pid 16588] AH02238: Unable to configure RSA server private key
[Mon Jan 11 20:13:28.477552 2021] [ssl:emerg] [pid 16588] SSL Library Error: error:0B080074:x509 certificate routines:X509_check_private_key:key values mismatch
[Mon Jan 11 20:32:18.509623 2021] [ssl:warn] [pid 17594] AH01909: RSA certificate configured for d1-fly.turby.com.br:443 does NOT include an ID which matches the server name
[Mon Jan 11 20:32:18.509673 2021] [ssl:emerg] [pid 17594] AH02238: Unable to configure RSA server private key
[Mon Jan 11 20:32:18.509699 2021] [ssl:emerg] [pid 17594] SSL Library Error: error:0B080074:x509 certificate routines:X509_check_private_key:key values mismatch
Podem me ajudar a tentar resolver esta situação?
