What "also failed" - please use more words.
dorian@carry:~$ sudo certbot --nginx -v
Now it requires me to choose the domains and the process that follows, but in the end it fails: I'll show you.
If you already have cert(s), then please use:
sudo certbot renew
If you are unsure about what certificate(s) you have, use:
sudo certbot certificates
Please take your time to make proper posts with all the informaton (i.e., the entire output) instead of spreading snippets of output into multiple posts.
Domain: www.********.com
Detail: 2a02:4780:10:4027::1: Invalid response from http://www.*******.com/.well-known/acme-challenge/wlNhskLaE0_3LMUEPtcAcWEPkpraT8hnxYo-v36IjOw: 404
dorian@carry:~$
Why are you hiding the domain name?
Does your site work correctly via IPv6?
Okay, am verry sorry.
I concur with Rudy, we need the actual hostname or hostnames for which you're trying to get a certificate for. It's actually mandatory to disclose as also mentioned in the questionnaire mentioned by Bruce earlier.
(Might be some IPv4 vs. IPv6 issue.)
My domain is: http://www.carry.assistanceserves.fr/
My web server is (include version): Ubuntu 22.04 64bit
The operating system my web server runs on is (include version): No LSB modules are available.
Distributor ID: Ubuntu
Description: Ubuntu 22.04.2 LTS
Release: 22.04
Codename: jammy
I can login to a root shell on my machine (yes or no, or I don't know): YES
I'm using a control panel to manage my site (no, or provide the name and version of the control panel): NO
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 1.21.0
I'm not English, I'm French and I don't understand English very well, which is why I express myself with the few words I know in English ![]()
Result to sudo cerbot --nginx -v:
1: carry.assistanceserves.fr
2: www.carry.assistanceserves.fr
blank to select all options shown (Enter 'c' to cancel): 1 2
Requesting a certificate for carry.assistanceserves.fr and www.carry.assistanceserves.fr
http-01 challenge for carry.assistanceserves.fr
http-01 challenge for www.carry.assistanceserves.fr
Challenge failed for domain carry.assistanceserves.fr
Challenge failed for domain www.carry.assistanceserves.fr
Domain: carry.assistanceserves.fr
Detail: 2a02:4780:10:4027::1: Invalid response from http://carry.assistanceserves.fr/.well-known/acme-challenge/tS7Lxv_Sou15a-ZkSjcqxDCkLQmoVKmRfwu0Uap2iRg: 404
Domain: www.carry.assistanceserves.fr
Detail: 2a02:4780:10:4027::1: Invalid response from http://www.carry.assistanceserves.fr/.well-known/acme-challenge/Gkt__Yejj6ep-ivGEUR6AqyMoohgDCPtOi7uhbnM3pU: 404
dorian@carry:~$
I'm really sorry for the late reply.
Hm, interesting. I would have expected your IPv6 not working entirely, but for some reason your IPv6 shows the default nginx welcome page, but your IPv4 is showing a 404 file not found even when simply surfing to your website.
Is your website supposed to be operational? Or is the default nginx welcome page something you'd expect? Or the 404 file not found?
In any case I'd like to see the entire output of the command sudo nginx -T. Please put three backticks (```) before and after (on their own line) the output of that command when posting it here for better readability.
Also interesting is to see that the 404 file not founds for the challenge file differ between IPv4 and IPv6 when looking at the headers. So this leads me to believe either their configuration is completely different in nginx (hence the required output mentioned above) or the servers might be entirely different (but by chance both having nginx 1.18.0 running on Ubuntu).
Supplemental information: Port 443 is not Open but filtered, at least for IPv4.
$ nmap -Pn -p80,443 www.carry.assistanceserves.fr
Starting Nmap 7.80 ( https://nmap.org ) at 2023-07-11 19:45 UTC
Nmap scan report for www.carry.assistanceserves.fr (191.101.14.47)
Host is up (0.043s latency).
Other addresses for www.carry.assistanceserves.fr (not scanned): 2a02:4780:10:4027::1
PORT STATE SERVICE
80/tcp open http
443/tcp filtered https
Nmap done: 1 IP address (1 host up) scanned in 2.27 seconds
$ nmap -Pn -p80,443 carry.assistanceserves.fr
Starting Nmap 7.80 ( https://nmap.org ) at 2023-07-11 19:46 UTC
Nmap scan report for carry.assistanceserves.fr (191.101.14.47)
Host is up (0.042s latency).
Other addresses for carry.assistanceserves.fr (not scanned): 2a02:4780:10:4027::1
PORT STATE SERVICE
80/tcp open http
Nmap done: 1 IP address (1 host up) scanned in 2.02 seconds
And curl -Ii http://www.carry.assistanceserves.fr returned HTTP/1.1 404 Not Found, again at least for IPv4.
$ curl -Ii http://www.carry.assistanceserves.fr/
Server: nginx/1.18.0 (Ubuntu)
Date: Tue, 11 Jul 2023 19:50:00 GMT
Content-Type: text/html
Content-Length: 179
X-Frame-Options: DENY
X-Content-Type-Options: nosniff
Referrer-Policy: same-origin
Yes, my website is up and running and I was expecting a non-functional page on the home page.
[sudo] password for dorian:
user www-data;
worker_processes auto;
pid /run/nginx.pid;
events {
worker_connections 768;
# multi_accept on;
http {
# Basic Settings
sendfile on;
tcp_nopush on;
types_hash_max_size 2048;
# server_tokens off;
# SSL Settings
ssl_protocols TLSv1 TLSv1.1 TLSv1.2 TLSv1.3; # Dropping SSLv3, ref: POODLE
ssl_prefer_server_ciphers on;
# Logging Settings
# Gzip Settings
gzip on;
# gzip_vary on;
# gzip_proxied any;
# gzip_comp_level 6;
# gzip_buffers 16 8k;
# gzip_http_version 1.1;
# Virtual Host Configs
#mail {
# # See sample authentication script at:
# # http://wiki.nginx.org/ImapAuthenticateWithApachePhpScript
# # auth_http localhost/auth.php;
# # pop3_capabilities "TOP" "USER";
# # imap_capabilities "IMAP4rev1" "UIDPLUS";
# server {
# listen localhost:110;
# protocol pop3;
# proxy on;
# server {
# listen localhost:143;
# protocol imap;
# proxy on;
# configuration file /etc/nginx/modules-enabled/50-mod-http-geoip2.conf:
load_module modules/ngx_http_geoip2_module.so;
# configuration file /etc/nginx/modules-enabled/70-mod-stream-geoip2.conf:
load_module modules/ngx_stream_geoip2_module.so;
types {
text/html html htm shtml;
text/css css;
text/xml xml;
image/gif gif;
image/jpeg jpeg jpg;
application/javascript js;
application/atom+xml atom;
application/rss+xml rss;
text/mathml mml;
text/plain txt;
text/vnd.sun.j2me.app-descriptor jad;
text/vnd.wap.wml wml;
text/x-component htc;
image/png png;
image/tiff tif tiff;
image/vnd.wap.wbmp wbmp;
image/x-icon ico;
image/x-jng jng;
image/x-ms-bmp bmp;
image/svg+xml svg svgz;
image/webp webp;
application/font-woff woff;
application/java-archive jar war ear;
application/json json;
application/mac-binhex40 hqx;
application/msword doc;
application/pdf pdf;
application/postscript ps eps ai;
application/rtf rtf;
application/vnd.apple.mpegurl m3u8;
application/vnd.ms-excel xls;
application/vnd.ms-fontobject eot;
application/vnd.ms-powerpoint ppt;
application/vnd.wap.wmlc wmlc;
application/vnd.google-earth.kml+xml kml;
application/vnd.google-earth.kmz kmz;
application/x-7z-compressed 7z;
application/x-cocoa cco;
application/x-java-archive-diff jardiff;
application/x-java-jnlp-file jnlp;
application/x-makeself run;
application/x-perl pl pm;
application/x-pilot prc pdb;
application/x-rar-compressed rar;
application/x-redhat-package-manager rpm;
application/x-sea sea;
application/x-shockwave-flash swf;
application/x-stuffit sit;
application/x-tcl tcl tk;
application/x-x509-ca-cert der pem crt;
application/x-xpinstall xpi;
application/xhtml+xml xhtml;
application/xspf+xml xspf;
application/zip zip;
application/octet-stream bin exe dll;
application/octet-stream deb;
application/octet-stream dmg;
application/octet-stream iso img;
application/octet-stream msi msp msm;
application/vnd.openxmlformats-officedocument.wordprocessingml.document docx;
application/vnd.openxmlformats-officedocument.spreadsheetml.sheet xlsx;
application/vnd.openxmlformats-officedocument.presentationml.presentation pptx;
audio/midi mid midi kar;
audio/mpeg mp3;
audio/ogg ogg;
audio/x-m4a m4a;
audio/x-realaudio ra;
video/3gpp 3gpp 3gp;
video/mp2t ts;
video/mp4 mp4;
video/mpeg mpeg mpg;
video/quicktime mov;
video/webm webm;
video/x-flv flv;
video/x-m4v m4v;
video/x-mng mng;
video/x-ms-asf asx asf;
video/x-ms-wmv wmv;
video/x-msvideo avi;
# configuration file /etc/nginx/sites-enabled/default:
# https://www.nginx.com/resources/wiki/start/
# https://www.nginx.com/resources/wiki/start/topics/tutorials/config_pitfalls/
# https://wiki.debian.org/Nginx/DirectoryStructure
# In most cases, administrators will remove this file from sites-enabled/ and
# leave it as reference inside of sites-available where it will continue to be
# updated by the nginx packaging team.
# This file will automatically load configuration files provided by other
# applications, such as Drupal or Wordpress. These applications will be made
# available underneath a path with that package name, such as /drupal8.
listen 80 default_server;
# SSL configuration
root /var/www/html;
server_name _;
try_files $uri $uri/ =404;
#location ~ \.php$ {
# include snippets/fastcgi-php.conf;
# # With php-fpm (or other unix sockets):
# fastcgi_pass unix:/run/php/php7.4-fpm.sock;
# # With php-cgi (or other tcp sockets):
# fastcgi_pass 127.0.0.1:9000;
# concurs with nginx's one
#location ~ /\.ht {
# deny all;
#server {
# listen 80;
# listen [::]:80;
# server_name example.com;
# root /var/www/example.com;
# index index.html;
# location / {
# try_files $uri $uri/ =404;
# configuration file /etc/nginx/sites-enabled/payment:
listen 80;
server_name carry.assistanceserves.fr www.carry.assistanceserves.fr;
location = /favicon.ico { access_log off; log_not_found off; }
location /static/ {
root /home/dorian/payment/;
include proxy_params;
proxy_pass http://unix:/run/payment.sock;
# configuration file /etc/nginx/proxy_params:
proxy_set_header Host $http_host;
dorian@carry:~$
Your default server is the only one listening on IPv6
You should also listen to IPv6 in this server block
Please like this?
listen 80;
listen [::]:80;
location /static/ {
And do I change the IPv6 default mode in the nginx default file?
Yeah, great. We're good now.
Thank you very much.
You're all bosses.
My respects again.
