Hello everyone,
My domain is: lucianograpsa.com
I ran this command: sudo certbot-auto --apache
output
http-01 challenge for lucianograpsa.com
Unable to find a virtual host listening on port 80 which is currently needed for Certbot to prove to the CA that you control your domain. Please add a virtual host for port 80.
I ran this command: sudo certbot-auto -a webroot -i apache
output
Input the webroot for lucianograpsa.com: (Enter 'c' to cancel): /var/www/lucianograpsa.com
Encountered exception during recovery:
File "/opt/eff.org/certbot/venv/local/lib/python2.7/site-packages/certbot/error_handler.py", line 108, in_call_registered self.funcs[-1]()
File "/opt/eff.org/certbot/venv/local/lib/python2.7/site-packages/certbot/auth_handler.py", line 220, in_cleanup_challenges self.auth.cleanup(achalls)
File "/opt/eff.org/certbot/venv/local/lib/python2.7/site-packages/certbot/plugins/webroot.py", line 224, in cleanup os.remove(validation_path)
OSError: [Errno 2] No such file or directory: '/var/www/lucianograpsa.com/.well-known/acme-challenge/lVr7eO4agPfveOnW07iWZ-0rRDF4UJxTFYRBrG2R5Fc'
Couldn't create root for lucianograpsa.com http-01 challenge responses: [Errno 13] Permission denied: '/var/www/lucianograpsa.com/.well-known'
My web server Apache 2.4.10
The operating system my web server runs on is: Debian 8
I can login to a root shell on my machine.
I’m using ISPConfig 3.1.6 to manage my site
The version of my client is certbot 0.32.0
Thank you for your time,
Kind Regards!
