It is complaining that the directory doesn't exist.
Let's check on that.
Please show:
dir C:\Apache24\htdocs
I actually have a new problem.
My software no longer responds under its url http://dolibarr.descartesetdesjeux.com/dolibarr
nor by its public IP: http://92.182.87.21/dolibarr or even my private IP http://192.168.1.200
I'm looking for the cause.
Here is the return of the order that you asked me for:
C:\Users\Dolibarr>dir C:\Apache24\htdocs
Le volume dans le lecteur C s’appelle Windows
Le numéro de série du volume est 30D3-D105
Répertoire de C:\Apache24\htdocs
18/10/2023 17:21 .
07/10/2023 12:51 ..
21/10/2023 18:37 dolibarr
07/10/2023 13:00 1 375 304 dolibarr_install.log
06/10/2023 20:32 46 index.html
2 fichier(s) 1 375 350 octets
3 Rép(s) 199 935 647 744 octets libres
Can you also tell me the tags you use to clean up the commands please? ![]()
