ERR_SSL_PROTOCOL_ERROR help!
certbot/1.13.0
Apache/2.4.29
domain: onetopstudios.com
I got the certificate using the following command:
certbot .. and number select
After ACMEv1 Brownout, it suddenly doesn't work! It is the same symptom even if you receive a new certificate
I know ACME v2 will be set automatically. is not it?
apache conf:
<VirtualHost *:80>
	ServerName onetopstudios.com
	ServerAlias www.onetopstudios.com
	RewriteEngine on
	RewriteCond %{SERVER_NAME} =onetopstudios.com [OR]
	RewriteCond %{SERVER_NAME} =www.onetopstudios.com
	RewriteRule ^ https://onetopstudios.com%{REQUEST_URI} [END,NE,R=permanent]
</VirtualHost>
<VirtualHost *:443>
	DocumentRoot /var/www/onetopnews
	<Directory /var/www/onetopnews>
		Options FollowSymLinks
		AllowOverride All
		Order allow,deny
		Allow from all
	</Directory>
	DirectoryIndex index.php index.html
	ErrorDocument 404 404.php
	SSLCertificateFile /etc/letsencrypt/live/onetopstudios.com/fullchain.pem
	SSLCertificateKeyFile /etc/letsencrypt/live/onetopstudios.com/privkey.pem
</VirtualHost>
Hi @Myodan
please check the fundamental / minimal port 443 configuration
https://httpd.apache.org/docs/2.4/ssl/ssl_howto.html
Looks like you have created that config manual - the most important directive is missing.
