ERR_SSL_PROTOCOL_ERROR after Cert Renewal
My domain is:stxdigitizing.com
I ran this command: n/a
It produced this output: www.stxdigitizing.com sent an invalid response (err_ssl_protocol_error)
after server update/upgrade and certbot renew command. Server is behind HaProxy.
My web server is (include version): Apache/2.4.29 (Ubuntu)
ubuntu 18.04.5 LTS
Yes
No
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 0.31.0
You maybe just need to restart apache but you should also check your openssl ciphers: http://httpd.apache.org/docs/2.0/ssl/ssl_faq.html#ciphers
Yeah, something is not right.
http to www works, but base domain has issues:
curl -Iki http://www.stxdigitizing.com/
Date: Wed, 30 Sep 2020 04:21:25 GMT
Server: Apache/2.4.29 (Ubuntu)
curl -Iki http://stxdigitizing.com/
HTTP/1.0 503 Service Unavailable
Cache-Control: no-cache
Connection: close
Content-Type: text/html
and the https side seems to be serving http content.
You might be missing "sslengine on".
sslengine on i'm assuming is in the virtual host file or should be in the host file?
Yes, it goes in the server block with the 443 listener and cert files.
so i decided to run wireshark to see what was going on. I fat fingered the destination port on the NAT to the proxy so it was incorrect. it's working now. But not sure on how the Https is serving up Http Content. Would it have to do with the Rewrite Engine on.
If you care to show your HTTPS block maybe I can see what is wrong there.
If you're unsure about which file it is in, try first showing the output of:
sudo apachectl -S
VirtualHost configuration:
*:443 stxdigitizing.com (/etc/apache2/sites-enabled/stxdigitizing-le-ssl.conf:2)
*:80 stxdigitizing.com (/etc/apache2/sites-enabled/stxdigitizing.conf:1)
ServerRoot: "/etc/apache2"
Define: DUMP_VHOSTS
Define: DUMP_RUN_CFG
User: name="www-data" id=33
Group: name="www-data" id=33
Please show this file with:
cat /etc/apache2/sites-enabled/stxdigitizing-le-ssl.conf
# The ServerName directive sets the request scheme, hostname and port that # the server uses to identify itself. This is used when creating # redirection URLs. In the context of virtual hosts, the ServerName # specifies what hostname must appear in the request's Host: header to # match this virtual host. For the default virtual host (this file) this # value is not decisive as it is used as a last resort host regardless. # However, you must set it for any further virtual host explicitly. #ServerName www.example.com
    ServerAdmin webmaster@stxdigitizing.com
    ServerName stxdigitizing.com
    ServerAlias www.stxdigitizing.com
    DocumentRoot /var/www/stxdigitizing/
    Protocols h2 http/1.1
    Header always set Strict-Transport-Security "max-age=63072000"
    # error, crit, alert, emerg.
    # modules, e.g.
    #LogLevel info ssl:warn
    ErrorLog /var/log/apache2/error.log
    CustomLog /var/log/apache2/access.log combined
    #SSLProtocol all -SSLv2 -SSLv3 -TLSv1 -TLSv1.1
#SSLEngine on
SSLCertificateFile /etc/letsencrypt/live/stxdigitizing.com/fullchain.pem
SSLCertificateKeyFile /etc/letsencrypt/live/stxdigitizing.com/privkey.pem
SSLCipherSuite ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-CHACHA20-POLY1305:ECDHE-RSA-CHACHA20-POLY1305$
SSLHonorCipherOrder off
SSLSessionTickets off
SSLUseStapling On
SSLStaplingCache "shmcb:logs/ssl_stapling(32768)"
Why is that off?
i just turned it back on now. probably didn't save file when i backed out of vim
Restart Apache and let's see...
Much better now:
curl -Iki https://www.stxdigitizing.com/
HTTP/1.1 200 OK
Date: Wed, 30 Sep 2020 05:37:45 GMT
Strict-Transport-Security: max-age=63072000
Upgrade: h2
Connection: Upgrade
Last-Modified: Mon, 24 Feb 2020 05:04:05 GMT
ETag: "2073-59f4b4cf3173a"
Accept-Ranges: bytes
Content-Length: 8307
Vary: Accept-Encoding
That is odd I remember SSLEngine being in the Virtual Host file and after an update it was missing and i didn't even notice it. Have you seen that happen before? Anywho, Thanks for the Help!
Never seen that happen on it's own...
It's not even Halloween!
Glad to see that all is well.
Cheers from Miami :beers:
