My domain is: ayeitszoe.com
I ran this command: I followed all the instructions listed on Certbot - Osx Webproduct.
My HTTP website is running Web Hosting Product on MacOS.
Not really sure what happened but after following the instructions, my site can no longer be reached. At first, I thought it was an issue with the name servers but after checking, still no luck. I'm a noob at this and I'm sure I shouldn't have touched everything since my site is hosted on Blogger anyway.
It produced this output: ERR_CONNECTION_CLOSED / Safari When It Can't Establish a Secure Connection to Server
My web server is (include version): not sure
The operating system my web server runs on is (include version): not sure
My hosting provider, if applicable, is: run on Blogger
I can login to a root shell on my machine (yes or no, or I don't know): i don't know
or certbot-auto --version
if you're using Certbot): command not found: certbot-auto. I think the issue happened after installing Homebrew but again, I'm not sure since I'm a noob at this.
I checked on https://check-your-website.server-daten.de/?q=ayeitszoe.com. Apparently, my site is on loop. Is there any fix to this?
