Enable SSL Let’s Encrypt on hosting using DirectAdmin
Hi everybody,
Today, I am going to show everyone how to automatically enable Let’s Encrypt on hosting using DirectAdmin
Step 1: Log into Hosting then access SSL Certificates
Step 2: At the SSL Certificates interface, tick Free & automatic certificate from Let’s Encrypt then check the Common Name box to see if the domain is correct (Note: Domain must be a form without www)
Note: For subdomains, you should uncheck the form www.sub.domain.com
After checking it correctly, scroll down and click the Save button
If successful you will receive a notification
copywrite by GamesBX2
