They’re redirecting to https://www…
Yes there is a new file Here it is!
<VirtualHost *:443>
servername elami.mk
serveralias www.elami.mk *.elami.mk
ServerAdmin webmaster@elami.mkDocumentRoot /home/elami_mk/www/public_html <Directory /> require all granted Options FollowSymLinks AllowOverride None Options +Indexes +FollowSymLinks +MultiViews +ExecCGI -MultiViews +SymLinksIfOwnerMatch AllowOverride All Order allow,deny Allow from all </Directory> <IfModule mod_fastcgi.c> AddHandler php7-fcgi .php Action php7-fcgi /php7-fcgi Alias /php7-fcgi /usr/lib/cgi-bin/php7-fcgi FastCgiExternalServer /usr/lib/cgi-bin/php7-fcgi -socket /var/run/php7.3-fpm-elami_mk.sock -pass-header Authorization <Directory /usr/lib/cgi-bin> require all granted </Directory> </IfModule> <FilesMatch \.php$> SetHandler "proxy:unix:/var/run/php7.3-fpm-elami_mk.sock|fcgi://localhost/" </FilesMatch> ScriptAlias /cgi-bin/ /usr/lib/cgi-bin/ ErrorLog ${APACHE_LOG_DIR}/web_website_url.log # Possible values include: debug, info, notice, warn, error, crit, AddHandler php7-fcgi .php Action php7-fcgi /php7-fcgi Alias /php7-fcgi /usr/lib/cgi-bin/php7-fcgi FastCgiExternalServer /usr/lib/cgi-bin/php7-fcgi -socket /var/run/php7.3-fpm-elami_mk.sock -pass-header Authorization <Directory /usr/lib/cgi-bin> require all granted </Directory> </IfModule> <FilesMatch \.php$> SetHandler "proxy:unix:/var/run/php7.3-fpm-elami_mk.sock|fcgi://localhost/" </FilesMatch> ScriptAlias /cgi-bin/ /usr/lib/cgi-bin/ ErrorLog ${APACHE_LOG_DIR}/web_website_url.log # Possible values include: debug, info, notice, warn, error, crit, # alert, emerg. LogLevel error CustomLog ${APACHE_LOG_DIR}/web_website_url.log combined
SSLCertificateFile /etc/letsencrypt/live/elami.mk/fullchain.pem
SSLCertificateKeyFile /etc/letsencrypt/live/elami.mk/privkey.pem
You are welcome.
But we are not done yet.
Now that you got the secure site up.
You need to decide if you want to redirect all traffic to HTTPS.
And also to which name www or no www.Essentially there exist four sites:
http://site
http://www.site
https://site
https://www.site
Three should redirect and end up at the fourth one.
[you need to decide which]
If it doesn't matter then I would choose
for the sake of simplicity
The * won't work so well with HTTPS.
The cert only has two names in it.
So replace those lines with:
servername elami.mk
And then give you site a full once over at:
https://check-your-website.server-daten.de/
and at https://www.ssllabs.com/
Let’s review the redirection code in use:
http site has:
RedirectMatch permanent ^/(.*)$ http://elami.mk/$1
But that is being ignored and overridden by:
X-Redirect-By: WordPress
https site has:
I believe I fixed it
https://elami.mk/
Seems contrary to your instinct but it works just as well.
[and can be reversed at any time - the cert will allow either name]
Ahh I see I will leave as is but I know where to change it now. Thank you very much!!!
rinse and repeat for the other sites…
cheers
You are a life saver!
I owe you!
Thank you
Feel free to donate to LetsEncrypt [https://letsencrypt.org/donate/]
And/Or just buy me a beer (virtually) [https://beer4.work/]
[rest assured I will drink it in your honor - LOL]
There
is your topic.
