During secondary validation - DNS problem: networking error looking up A
We have issues with one specific (sub)domain only, although other domains with the same name servers (NS: robotns3.second-ns.com, robotns2.second-ns.de, ns1.first-ns.de) renew without problems:
2020/07/20 09:00:50 Domain verification results for 'www.lsp.net': error.
  During secondary validation:
  DNS problem: query timed out looking up A for www.lsp.net
2020/07/27 09:00:48
  During secondary validation: No valid IP addresses found for www.lsp.net
2020/08/03 09:00:48 Domain verification results for 'www.lsp.net': error.
  DNS problem: SERVFAIL looking up A for www.lsp.net - the domain's nameservers may be malfunctioning
2020/08/10 09:00:48 Domain verification results for 'www.lsp.net': error.
  DNS problem: networking error looking up A for www.lsp.net
(Source: Logs of a weekly cronjob running Crypt-LE 0.35 on Windows Server 2016)
Edit: I was able to renew the certificate by running the cronjob manually again.
Hi @claas
your problem looks different. So I've moved it to a new topic.
That
says: The primary Letsencrypt servers are able to check your domain.
The secondary are not.
Looks like a regional firewall / blocking.
I'm not sure. The fact that one of the errors is "networking error" is suspicious :(, added to the circumstances of the original report. I really don't want to speculate but it could be that something is up with the remote VAs. Might be time to ask @lestaff (link to the original report).
Yes, sorry, my error.
Read the first three results, then moved it.
Time that Letsencrypt should check it.
Thanks for the heads up. I’m going to dig in and take a look.
Digging into the logs I found the following information:
There were two issuance attempts for www.lsp.net. During the first issuance attempt we received the following errors from a random selection of RVA nodes
2020-08-10T07:00:36.679916+00:00 boulder-va[5016]: useHwQo Remote VA "xxx".PerformValidation returned problem: dns :: No valid IP addresses found for www.lsp.net
2020-08-10T07:00:46.720078+00:00 boulder-va[5016]: qqjOgA0 Remote VA "yyy".PerformValidation returned problem: dns :: DNS problem: networking error looking up CAA for www.lsp.net
During the second issuance attempt several hours later DNS had propagated, we were able to successfully validate the domain, and issue a certificate. https://crt.sh/?id=3216017655
2020-08-10T11:21:50.680184+00:00 boulder-va[13370]: uofTDgA [AUDIT] Checked CAA records for www.lsp.net, [Present: true, Account ID: xxxxx, Challenge: http-01, Valid for issuance: true]
2020-08-10T11:21:53.548219+00:00 boulder-ca[25045]: ieCyiQ0 [AUDIT] Signing success: serial=[04f3665528260d3637a7c2e6c60fc28753f8] names=[lsp.net, www.lsp.net] certificate=...
I noticed that Hetzner has been having some infrastructure maintenance today, perhaps the first issuance attempt occurred at the worst possible time? https://twitter.com/hetznerstats?lang=en
Edit: I’m taking another look at the initial report from Increase in renewal DNS failures
Thanks for looking into this.
Indeed this second (manual) execution of our cronjob (after posting my reply in the forum) succeeded.
I looked into the maintenance announcements and DNS does not seem to have been affected by it.
Hi Phil,
Thanks!
Sorry for flagging you, but mainly I wanted to find out whether there is any indication of why the remote VAs themselves have begun reporting a "networking error" during the DNS exchange, as opposed to the actual rcode from the recursor or context timeout?
It would be good to know whether to treat that as a normal timeout, or temporary condition, or something that needs attention.
