To install the certificate on the Domoticz server I temporarily redirect port 80 redirection to 8080 from the Domoticz server’s local IP address. I do the same thing to renew the certificate but now it does not work for a reason that is unknown to me
I don’t now…
Is it redirected now?
NOTE:
Addresses: 2a01:e35:2f45:8980::1
82.244.88.152
No, he is not…
now he is…
Then it is difficult to troubleshoot the problem…
You still have a problem with IPv6:
wget -6 bandol.freeboxos.fr
--2019-11-17 20:07:57-- http://bandol.freeboxos.fr/
Resolving bandol.freeboxos.fr (bandol.freeboxos.fr)... 2a01:e35:2f45:8980::1
Connecting to bandol.freeboxos.fr (bandol.freeboxos.fr)|2a01:e35:2f45:8980::1|:80... connected.
HTTP request sent, awaiting response... 301 Moved Permanently
Location: https://bandol.freeboxos.fr:1969/index.php [following]
--2019-11-17 20:07:57-- https://bandol.freeboxos.fr:1969/index.php
Connecting to bandol.freeboxos.fr (bandol.freeboxos.fr)|2a01:e35:2f45:8980::1|:1969... ^C
wget -4 bandol.freeboxos.fr
--2019-11-17 20:08:04-- http://bandol.freeboxos.fr/
Resolving bandol.freeboxos.fr (bandol.freeboxos.fr)... 82.244.88.152
Connecting to bandol.freeboxos.fr (bandol.freeboxos.fr)|82.244.88.152|:80... connected.
--2019-11-17 20:08:04-- https://bandol.freeboxos.fr:1969/index.php
Connecting to bandol.freeboxos.fr (bandol.freeboxos.fr)|82.244.88.152|:1969... connected.
HTTP request sent, awaiting response... 302 Found
--2019-11-17 20:08:05-- https://bandol.freeboxos.fr:1969/login.php
Reusing existing connection to bandol.freeboxos.fr:1969.
HTTP request sent, awaiting response... 200 OK
Length: unspecified [text/html]
Saving to: ‘index.html’
Anyway, I don’t know much about Domoticz
[they do have a forum BTW: https://www.domoticz.com/forum/]
Can you modify the (vhost) config file it uses?
There is an active fire on IPV6 at the level of my Freebox
I know this forum, there is no solution. The problem does not come from Domoticz.
I do not know if there is a vhost file
Is there any way to get to the config files?
Thanks for your help.
Can you SSH to it?
Yes, I can SSH…
OK, get in and show:
ls -l /etc/nginx/sites-enabled/
root@domo:/etc/letsencrypt# ls -l /etc/nginx/sites-enabled/
ls: impossible d’accéder à /etc/nginx/sites-enabled/: Aucun fichier ou dossier de ce type
Please show:
ls -l /etc/nginx/
find / -name nginx.conf
If you are unable to reply.
Please send me a direct message or open another account and continue this topic.
To send direct message, click my ICON and choose “MESSAGE”
