@seroff,
Is there a firewall blocking on IPv6? Being unable to connect to the server usually is a firewall problem. Your hosting company can check that for you if you don't have access.
The SSL Labs test still fails to connect to the IPv6 server. (And I did clear the cache before running the test.)
Another test https://test-ipv6.rashodnik.cv.ua/ also fails to connect as does a ping test from IPv6 ping test for server, website, or network l Uptrends | Uptrends. That test returns Failed to connect
, Request timed out
, Destination could not be resolved
and Destination network is not reachable
. All this leads to a firewall blocking problem. Ask your hosting provider if they are blocking any ports on IPv6. Something is.
Edit: I should add that the apex domain cv.ua
doesn't have a cert.
Your domain, roshodnik.cv.ua
does not have any Whois records. It shows the domain as not being registered. Maybe they haven't propogated yet?
https://whois.domaintools.com/roshodnik.cv.ua
Whois Record Not Available
This domain is not registered.
But the good news is I see you finally got your cert for roshodnik.cv.ua
and www.roshodnik.cv.ua
Can you let us know if it was your host service provider that had the problem? That could help others in the future should they have a similar problem. Thank you.
