Domains not working after installing Cerificates
Please help:
Issues: I am using Ubuntu 22.04 and Apache2. After installing the certificate, the domain shows Apache default home page for HTTP and shows ERR_SSL_PROTOCOL_ERROR for HTTPS.
When I run sudo apachectl -S, I got the following:
193.122.182.108:443    connexverse.com (/etc/apache2/sites-enabled/connexverse.com-le-ssl.conf:2)
193.122.182.108:80     connexverse.com (/etc/apache2/sites-enabled/connexverse.com.conf:1)
ServerRoot: "/etc/apache2"
Define: DUMP_VHOSTS
Define: DUMP_RUN_CFG
User: name="www-data" id=33
It is clear the Main Document Root is not the one I configured in the conf file.
See below for conf files:
<VirtualHost connexverse.com:80>
    ServerAdmin admin@localhost
    ServerName connexverse.com
    ServerAlias www.connexverse.com
    DocumentRoot /home/jimin/mysite/
    Alias /static /home/jimin/static_env/static_root/
    <Directory /home/jimin/static_env/static_root/>
	Require all granted
    </Directory>
    Alias /media /home/jimin/static_env/media_root/
    <Directory /home/jimin/static_env/media_root/>
	Require all granted
    </Directory>
    <Directory /home/jimin/mysite/mysite/>
	<Files wsgi.py>
		Require all granted
	</Files>
    </Directory>
   WSGIDaemonProcess mysite python-path=/home/jimin/mysite  python-home=/home/jimin/venv
   WSGIProcessGroup mysite
   WSGIScriptAlias / /home/jimin/mysite/mysite/wsgi.py
RewriteEngine on
RewriteCond %{SERVER_NAME} =connexverse.com [OR]
RewriteCond %{SERVER_NAME} =www.connexverse.com
</VirtualHost>
<IfModule mod_ssl.c>
<VirtualHost connexverse.com:443>
	Require all granted
    </Directory>
	Require all granted
    </Directory>
	<Files wsgi.py>
		Require all granted
	</Files>
    </Directory>
   WSGIDaemonProcess mysites python-path=/home/jimin/mysite  python-home=/home/jimin/venv
SSLEngine On
SSLCertificateFile /etc/letsencrypt/live/connexverse.com/fullchain.pem
SSLCertificateKeyFile /etc/letsencrypt/live/connexverse.com/privkey.pem
</VirtualHost>
</IfModule>
My domain is: connexverse.com
I ran this command: sudo certbot renew --dry-run
Processing /etc/letsencrypt/renewal/connexverse.com.conf
http-01 challenge for connexverse.com
http-01 challenge for www.connexverse.com
Challenge failed for domain connexverse.com
Challenge failed for domain www.connexverse.com
Attempting to renew cert (connexverse.com) from /etc/letsencrypt/renewal/connexverse.com.conf produced an unexpected error: Some challenges have failed.. Skipping.
  /etc/letsencrypt/live/connexverse.com/fullchain.pem (failure)
**          (The test certificates below have not been saved.)
**          (The test certificates above have not been saved.)
   Domain: connexverse.com
   Type:   unauthorized
   Detail: 193.122.182.108: Invalid response from
   http://connexverse.com/.well-known/acme-challenge/vMThzepCpDD4zJgdOOc9bfjs1fE51QLTjOK7-VOWn-o:
   404
   Domain: www.connexverse.com
   Type:   unauthorized
   http://www.connexverse.com/.well-known/acme-challenge/cH8y5sRNQQ0R-Q_6kwYohGEraEybA01tyrB9jmnbGvI:
   404
Apache2
Hi @hjm0525, and welcome to the LE community forum :slight_smile:
It seems like that is no longer your IP.
Please show the output of:
curl ifconfig.io
Please stop generating new certificates. I can see you've issued 4 certificates already recently: crt.sh | connexverse.com
If issuance is not the problem (clearly), but there is something else going on, you shouldn't try to re-issue the certificate and somehow think that's magically going to fix something it didn't fix 3 times before.
My guess is your Apache doesn't recognise the VirtualHost sections as it's showing the default Ubuntu Apache page on port 80 as well as port 443 using HTTP. Probably due to the fact you have your hostname hardcoded in the <VirtualHost> section.
It's probably a better idea to use <VirtualHost *:80> and <VirtualHost *:443>. Change that, reload Apache and see what it did.
And yet, it does show:
Agreed to that :slight_smile:
Yes, but Apache doesn't actually use those..
There's no HTTP to HTTPS redirect, no certificate in use and no fancy WSGI script output shown, only the default Apache page. Thus: those VirtualHost sections aren't actually used. They show up, they are configured, but not used when someone connects to it.
And (depending on the O/S which you failed to mention) something like:
ifconfig | grep net
@rg305 running ifconfig | grep net gives the following information:
    inet 10.0.0.184  netmask 255.255.255.0  broadcast 10.0.0.255
    inet6 fe80::17ff:fe11:4fae  prefixlen 64  scopeid 0x20<link>
    ether 02:00:17:11:4f:ae  txqueuelen 1000  (Ethernet)
    inet 127.0.0.1  netmask 255.0.0.0
    inet6 ::1  prefixlen 128  scopeid 0x10<host>
Well, there's your problem if you combine it with what I've mentioned ealier.
Running curl ifconfig.io gives me the follows.
193.122.182.108
Agreed, the vhosts are bound to an IP that is not found on the local system:
@Osiris
I changed to <VirtualHost *:80> and <VirtualHost *:443> . It works now. The issues is resolved. Thanks a lot.
