Domain using wrong certificate
My domain is: https://26484959-production-backend.app.orior.io/
I have a ERR_CERT_DATE_INVALID error on it and indeed the certificate showed is outdated, but I have another certificate for this domain which is valid (I can see it when I run the kubernetes command kubectl describe certificate). Why isn't this valid certificate used instead?
I even receive some emails from Let's Encrypt saying that a certificate for that will expire at a date which is later than today so there are definitely several valid certificates on that domain that Let's Encrypt is aware of
Thanks in advance!
Hi @amaury, and welcome to the LE community forum :slight_smile:
Is there a kubectl command to list all the certs?
Is there one to delete expired certs?
Hi @rg305 thanks for your answer!
There are commands for that yes and actually I can't find the one that is used (the expired one), it's not in the list. So I'm not really sure how it can be used/found by Let's Encrypt?
Maybe it's just "old" info and the service simply needs to be restarted to use the latest cert.
