Does auto-update need any other port then 80/443?
I have a simple ubuntu 14.04 server with a pretty default firewall, allowing 80/443 and some other ports.
Problem is, if the firewall is enabled, letsencrypt-auto says:
WARNING: unable to check for updates.
and requesting/renewing certificates doesn't work (I use virtualmin for this).
as soon as I disable the firewall, everything is fine.
root@:/opt/letsencrypt# iptables -L |grep http
ACCEPT     tcp  --  anywhere             anywhere             tcp dpt:http
ACCEPT     tcp  --  anywhere             anywhere             tcp dpt:https
Does the firewall block outbound ?
Yes. (But not port 80/443 as you can see from the iptables copy/paste in my post)
