*.oakdaleirrigation.com
I have not ran a command yet.
N/A
IIS
Windows Server 2016
On-Prem
I have a split DNS environment (internal server DNS name is different than the external DNS name). If I install the client and generate a certificate i am assuming it will pull the FQDN (internal DNS name) which will not match the public facing name. Do I need 2 separate certificates or can I specify the name on the certificate to be the external name? I want the external DNS name to be on the certificate so that the applications we are hosting will resolve properly.
Your assumption is incorrect: the ACME client doesn't validate the FQDN, the (remote) Let's Encrypt validation server does. So it'll try to connect to the IP address resolved from the public, external DNS (http-01 or tls-alpn-01 challenges) or use the authorative DNS servers for validation (dns-01 challenge).
In addition to what @Osiris said, LetsEncrypt can only issue Certificates to the public internet / external DNS names. You can not get a Certificate from LetsEncrypt for the internal LAN names.
Hi @mballinger and welcome to the LE community forum
I presume the reason being that you are using the exact same set of FQDNs and simply want to return a different set of IPs from each zone.
[external IPs from external zone - internal IPs from internal zone]
That said, since you plan on requesting a wildcard cert, you will have to ensure the ACME client can update the actual DNS zone for the real Internet domain - OR process the request manually (NOT recommended).
So the first hurdle is using a DNS Service Provider (DSP) that supports zone updates via API.
The second hurdle is using an ACME client that has a plugin for that DSP.
Feel free to ask questions and/or for advice along the way.
