DNS problem with SSL
I Can not receive an SSL/TLS certificate for dakiaspharma.gr
Details
"identifier": {
"type": "dns",
"value": "dakiaspharma.gr"
"status": "invalid",
"expires": "2024-02-16T10:39:15Z",
"challenges": [
"type": "http-01",
"error": {
"type": "urn:ietf:params:acme:error:dns",
"detail": "DNS problem: NXDOMAIN looking up A for dakiaspharma.gr - check that a DNS record exists for this domain; DNS problem: NXDOMAIN looking up AAAA for dakiaspharma.gr - check that a DNS record exists for this domain",
"status": 400
"url": "https://acme-v02.api.letsencrypt.org/acme/chall-v3/313305703807/YiOQZg",
"token": "ERNtp0VtJ8kHd9wGUGAcOrDj_ifdJBlv9jb-v6j8L10",
"validated": "2024-02-09T10:39:18Z"
did you type that domain name right?
that error usually means the domain hasn't been bought/registered.
Thank U
According to Registry of .gr and .ελ Domain Names your domain is:
dakiaspharma.gr : Pending registration declaration
With an unhappy smiley in front of it. :frowning:
Whatever that may be :man_shrugging:t2: Maybe ask your register :slight_smile:
Thank U so much, i am really new in this!!!
Still can not issue an SSL/TLS certificate for dakiaspharma.gr
Although I have the registration.
Details
Could not issue a Let's Encrypt SSL/TLS certificate for dakiaspharma.gr. Authorization for the domain failed.
Details
Invalid response from https://acme-v02.api.letsencrypt.org/acme/authz-v3/314797318507.
Details:
Type: urn:ietf:params:acme:error:dns
Status: 400
Detail: DNS problem: NXDOMAIN looking up A for dakiaspharma.gr - check that a DNS record exists for this domain; DNS problem: NXDOMAIN looking up AAAA for dakiaspharma.gr - check that a DNS record exists for this domain
To get a certificate using the HTTP Challenge you must first setup your domain / website to work for HTTP requests. You will need an A and/or AAAA record in your DNS to point to your web server. And, setup your webserver to handle HTTP.
Once you have those working you can try again to get the cert. Your hosting service can help you. Or, many other forums to help setup web services.
Thanks U.
I will try
:blush:
Assuming @Ismpol actually has a hosting provider :wink: Which is not required of course, as one can register a domain and host the services themselves for example :slight_smile: (Which you know, but just for general clarification.)
Unfortunately @Ismpol has not used the questionnaire which should have shown when opening this thread in the Help section, so we don't know at this moment :man_shrugging:t2:
Thank u so much for your answer
Yes I do have a hosting provider
U R right, I haven’t filled the questionnaire
Sorry for that I will try it
immediately :blush: :crazy_face:
My domain is: "dakiaspharma.gr"
the name servers
NS ns1145.papaki.gr.
NS ns2145.papaki.gr.
My hosting provider, if applicable, is: papaki.com
And I bought a Standard - Linux – GR plan
I'm using a control panel to manage my site (no, or provide the name and version of the control panel): I don't know
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): I don't know
Looks like their Standard plan includes a free Let's Encrypt certificate. Probably nothing you can do yourself manually.
Please contact your hosting provider and ask them how you should set up your domain and hosting.
:flushed:
Thank U Thank U
i will ask them
