DNS Problem - Wich DNS?
My domain is: flimando.tk
I ran this command: certbot certonly -d flimando.tk
It produced this output: Certbot failed to authenticate some domains (authenticator: nginx). The Certificate Authority reported these problems:
Domain: flimando.tk
Type: dns
Detail: no valid A records found for flimando.tk; no valid AAAA records found for flimando.tk
My hosting provider, if applicable, is: freenom.com
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 1.21.0
My Question is: Which A Records and which AAAA Record should i use?
Welcome to the community @Fredmee
You should setup A (and/or AAAA) records at your DNS provider freenom
You can use this google dig tool to lookup your records. You can see right now there are no A or AAAA records.
There are records for the "www" name:
Addresses: 2607:f8b0:4008:801::2013
           142.250.64.179
Aliases:   www.flimando.tk
