DNS problem: SERVFAIL looking up CAA
#1
agent.hy1.com
DNS problem: SERVFAIL looking up CAA for agent.hy1.com
nginx
centos6.0
no
#2
Hi @patricelee
that looks bad ( https://sslmate.com/caa/ ):
agent.hy1.com has broken DNS servers that do not handle CAA properly: Could not contact DNS servers
Same with letsdebug:
https://letsdebug.net/agent.hy1.com/7646
DNS response for agent.hy1.com/CAA did not have an acceptable response code: SERVFAIL
Looks terrible. Are you able to create a new CAA setting for agent.hy1.com?
Use sslmate to see the format.
#3
DNS.COM has issues.
  • Some of the DNS servers don’t respond.
  • They all have bugs; some servers have more and worse bugs than others.
  • Some of them have different versions of the zone.
  • They don’t support case randomization. That is totally valid, but Let’s Encrypt’s resolver either requires that it is supported or enters a fallback mode, which almost always works, but sometimes doesn’t.
The other issues – plus having a lot of servers, far away – make the fallback mode less reliable.
#4
Thank you for your reply
We have change the dns provider to ns1 and it work for us.
#5
