My goal is to use a certificate that uses Elliptical Curve based bey issued by letsEncrypt
Currently, I used openssl to generate it using “ecparam” and I am trying to get it signed by LetsEncrypt.
Please guide me in the right direction if there is a better way to do it.
My domain is: koshaparekh.tk
I ran this command: certbot certonly --dry-run --dns-cloudflare --dns-cloudflare-credentials ./cloudflare.ini --domain “koshaparekh.tk” --domain “*.koshaparekh.tk” --csr csr.pem
Plugins selected: Authenticator dns-cloudflare, Installer None
Enter email address (used for urgent renewal and security notices) (Enter ‘c’ to
cancel): kosha.parekh@gmail.com
Starting new HTTPS connection (1): acme-staging-v02.api.letsencrypt.org
agree in order to register with the ACME server at
https://acme-staging-v02.api.letsencrypt.org/directory
(A)gree/©ancel: A
dns-01 challenge for koshaparekh.tk
Unsafe permissions on credentials configuration file: ./cloudflare.ini
Starting new HTTPS connection (1): api.cloudflare.com
Waiting 10 seconds for DNS changes to propagate
Waiting for verification…
Challenge failed for domain koshaparekh.tk
Domain: koshaparekh.tk
Type: dns
Detail: DNS problem: SERVFAIL looking up CAA for tk -
Your account credentials have been saved in your Certbot
tmp$ dig koshaparekh.tk
My web server is (include version): I am using httpbin
The operating system my web server runs on is (include version): RHEL 8
My hosting provider, if applicable, is: I got a free domain from freenom and hosted it on Cloudflare
or certbot-auto --version
if you’re using Certbot): certbot 0.36.0
