My domain is: pipedproxy-yyz.kavin.rocks
I ran this command: certbot
certbot
1: pipedapi.kavin.rocks
2: pipedproxy-yyz.kavin.rocks
blank to select all options shown (Enter 'c' to cancel): 2
Requesting a certificate for pipedproxy-yyz.kavin.rocks
Domain: pipedproxy-yyz.kavin.rocks
Type: dns
Detail: DNS problem: SERVFAIL looking up A for pipedproxy-yyz.kavin.rocks - the domain's nameservers may be malfunctioning; no valid AAAA records found for pipedproxy-yyz.kavin.rocks
nginx 1.16.1
Alpine Linux 3.15
Yes
No
or certbot-auto --version
if you're using Certbot):
certbot 1.22.0
dig A pipedproxy-yyz.kavin.rocks @8.8.8.8
; <<>> DiG 9.16.24 <<>> A pipedproxy-yyz.kavin.rocks @8.8.8.8
;; global options: +cmd
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 41078
;; flags: qr rd ra ad; QUERY: 1, ANSWER: 1, AUTHORITY: 0, ADDITIONAL: 1
;; OPT PSEUDOSECTION:
; EDNS: version: 0, flags:; udp: 512
;; QUESTION SECTION:
;pipedproxy-yyz.kavin.rocks. IN A
;; ANSWER SECTION:
pipedproxy-yyz.kavin.rocks. 300 IN A 192.18.157.45
;; Query time: 20 msec
;; SERVER: 8.8.8.8#53(8.8.8.8)
;; WHEN: Wed Jan 26 19:10:00 UTC 2022
;; MSG SIZE rcvd: 71
