My domain is: inventively.com
The issue does indeed appear to be related to DNSSEC. Google’s public DNS fails to resolve the domain as well with a DNSSEC validation failure. dnsviz reports a couple of errors for your domain.
If I had to guess, I’d say you disabled DNSSEC support on the DNS side, but you didn’t remove the DS record from your registrar, which would make all queries from validating resolvers fail.
This was helpful, thanks! The issue was the erroneous DS record.
