Hi there,
I am trying to issue a certificate for css.paged.media.
ajung@dev ~ $ dig -t NS paged.media
; <<>> DiG 9.11.1-P3-RedHat-9.11.1-2.P3.fc26 <<>> -t NS paged.media
;; global options: +cmd
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 41734
;; flags: qr rd ra; QUERY: 1, ANSWER: 2, AUTHORITY: 0, ADDITIONAL: 1
;; OPT PSEUDOSECTION:
; EDNS: version: 0, flags:; udp: 4096
;; QUESTION SECTION:
;paged.media. IN NS
;; ANSWER SECTION:
paged.media. 86400 IN NS ns.namespace4you.de.
paged.media. 86400 IN NS ns2.namespace4you.de.
;; Query time: 162 msec
;; SERVER: 213.136.95.10#53(213.136.95.10)
;; WHEN: Fri Nov 03 13:27:09 CET 2017
;; MSG SIZE rcvd: 91
ajung@dev ~ $ ping css.paged.media
PING css.paged.media(vmd16513.contabo.host (2a02:c207:3001:6513::1)) 56 data bytes
64 bytes from vmd16513.contabo.host (2a02:c207:3001:6513::1): icmp_seq=1 ttl=62 time=37.5 ms
The DNS is properly configured, the related host is reachable .
However LE is unable to verify the DNS entry:
certbot certonly --standalone -d css.paged.media
tls-sni-01 challenge for css.paged.media
Failed authorization procedure. css.paged.media (tls-sni-01): urn:acme:error:connection :: The server could not connect to the client to verify the domain :: DNS problem: SERVFAIL looking up A for css.paged.media
Domain: css.paged.media
Type: connection
Detail: DNS problem: SERVFAIL looking up A for css.paged.media
File "/usr/bin/certbot", line 11, in <module>
load_entry_point('certbot==0.19.0', 'console_scripts', 'certbot')()
File "/usr/lib/python3.6/site-packages/certbot/main.py", line 861, in main
File "/usr/lib/python3.6/site-packages/certbot/main.py", line 786, in certonly
lineage = _get_and_save_cert(le_client, config, domains, certname, lineage)
File "/usr/lib/python3.6/site-packages/certbot/main.py", line 85, in _get_and_save_cert
File "/usr/lib/python3.6/site-packages/certbot/client.py", line 357, in obtain_and_enroll_certificate
certr, chain, key, _ = self.obtain_certificate(domains)
File "/usr/lib/python3.6/site-packages/certbot/client.py", line 318, in obtain_certificate
self.config.allow_subset_of_names)
File "/usr/lib/python3.6/site-packages/certbot/auth_handler.py", line 81, in get_authorizations
self._respond(resp, best_effort)
File "/usr/lib/python3.6/site-packages/certbot/auth_handler.py", line 138, in _respond
self._poll_challenges(chall_update, best_effort)
File "/usr/lib/python3.6/site-packages/certbot/auth_handler.py", line 202, in _poll_challenges
raise errors.FailedChallenges(all_failed_achalls)
certbot.errors.FailedChallenges: Failed authorization procedure. css.paged.media (tls-sni-01): urn:acme:error:connection :: The server could not connect to the client to verify the domain :: DNS problem: SERVFAIL looking up A for css.paged.media
I also tried the DNS with dnschecker.org and others…all green…just LE hates me.
What could be the problem?
Andreas
