DNS problem: query timed out
I am having issues generating an SSL cert for one of my domains.
The DNS query always times out.
I am hosting several other domains, all with an identical configuration in terms of nginx config, nameserver, DNS zone files, etc, and they are all working without issue.
I can't figure out why this one domain refuses to work and always times out, yet the rest are ok.
johnfordemotors.net
certbot certonly -d johnfordemotors.net -d www.johnfordemotors.net -v --webroot --webroot-path /srv/www/ssl-backend/public_html
Requesting a certificate for johnfordemotors.net and www.johnfordemotors.net
http-01 challenge for johnfordemotors.net
http-01 challenge for www.johnfordemotors.net
Using the webroot path /srv/www/ssl-backend/public_html for all unmatched domains.
Challenge failed for domain johnfordemotors.net
Challenge failed for domain www.johnfordemotors.net
  Domain: johnfordemotors.net
  Type:   dns
  Detail: DNS problem: query timed out looking up A for johnfordemotors.net; DNS problem: query timed out looking up AAAA for johnfordemotors.net
  Domain: www.johnfordemotors.net
  Type:   dns
  Detail: DNS problem: query timed out looking up A for www.johnfordemotors.net; DNS problem: query timed out looking up AAAA for www.johnfordemotors.net
nginx/1.14.1
AlmaLinux release 8.8
N/A (private cloud)
Yes
No
certbot 1.23.0
I have performed DNS lookups using a few different online services and they all return valid results, so as far as I can tell everything is setup correctly.
I have checked it serveral times using letsdebug.net and it returns an timeout error every time except once.
An example of another of my domains on the same server, nameserver, etc, that is working correctly is: www.velocitymotors.co.uk
Any assistance would be greatly appreciated as I am at a complete loss.
Trying to resolve your domain directly at both of your NSes from my RU and NL boxes end up with timeouts. DNSViz shows errors and warnings. Unboundtest also timeouts (though deciphering its output is somewhat above my pay grade). But public resolvers like 1.1.1.1 and 8.8.8.8 resolve just fine, curious.
Querying your velocitymotors domain also timeouts on my boxes, DNSViz is also stuck analyzing for a while. But does resolve fine on Unboundtest. Go figure.
Other volunteers might have some other ideas, but I would recommend contacting your DNS provider. Perhaps point them to this thread.
I have over 200 domains on the same nameserver, and all of them are able to generate certificates using certbot/letsencrypt without any issues or timeouts.
This issue is only affecting a single domain.
I've moved the domain to different nameservers and was able to generate a cert.
Would love to figure out what the actual cause was, but I can at least get the site up and running again for now
You need to have a triple PhD in quantum mechanics, IT and the fine art. Only then you're able to understand the dredge that Unbound produces.. :rofl:
