I ran this command: sudo -H ./letsencrypt-auto certonly --standalone -d star.vidalia.com.ph -d www.star.vidalia.com.ph
Debian GNU/Linux 8.11 (jessie)
Logs (/var/log/letsencrypt/letsencrypt.log)
File “/opt/eff.org/certbot/venv/local/lib/python2.7/site-packages/certbot/auth_handler.py”, line 154, in _poll_authorizations raise errors.AuthorizationError(‘Some challenges have failed.’) AuthorizationError: Some challenges have failed.
Your domain star.vidalia.com.ph has a DNS record, but www.star.vidalia.com.ph doesn’t. It looks like your DNS is hosted by Amazon AWS, so you should use your Amazon AWS control panel or other interface to add a DNS record for www.star.vidalia.com.ph in addition to your existing record for star.vidalia.com.ph.
As the documentation explains, revoking certificates does not affect the rate limits.
Adding www.star.vidalia.com.ph, as you’ve been doing, does avoid the duplicate certificate rate limit. If you add the missing DNS record, that will work.
I’ve been testing this command since yesterday sudo -H ./letsencrypt-auto certonly --standalone -d star.vidalia.com.ph -d www.star.vidalia.com.ph
The only goal I wanted for the star.vidalia.com.ph is to be able to show also using HTTPS
but still doesn’t worked. So what I thought those 5 command that I’ve been running, registered.
You said that when you ran the sudo -H ./letsencrypt-auto certificates command, it said No certs found; did you already delete something from this server, or did you use another server or application to generate the five previous certificates?
Copy the certificates and private keys from that other server, if they still exist and you still have access to them
Create the www.star.vidalia.com.ph name in DNS and create a new certificate that covers both names (which will not be considered a duplicate because it will cover a different combination of names)
Wait one week for the rate limit on duplicate certificate creation to expire
