DNS problem: NXDOMAIN
My domain is: sendboxsac.com
I use amazon aws lightsail, I already bought a domain in bluehost with ssl,
I want to add ssl to my website lightsail wordpress, please any help?
I got his error, links picture
Failed authorization procedure. sendboxsac.com (dns-01): urn:ietf:params:acme:error:dns :: DNS problem:
NXDOMAIN looking up TXT for _acme-challenge.sendboxsac.com - check that a DNS record exists for this dom
ain, sendboxsac.com (dns-01): urn:ietf:params:acme:error:dns :: DNS problem: NXDOMAIN looking up TXT for
_acme-challenge.sendboxsac.com - check that a DNS record exists for this domain
    Domain: sendboxsac.com
    Type: None
    Detail: DNS problem: NXDOMAIN looking up TXT for
    this domain
    Type: None
    this domain
Hi @JOHNESPINOZA
that’s expected, see your check, ~~20 minutes old - https://check-your-website.server-daten.de/?q=sendboxsac.com#txt
Your menu adds the domain name, so you have created one entry with two domain names _acme-challenge.sendboxsac.com.sendboxsac.com.
Create an entry only with _acme-challenge.
And if you want to create one certificate with two domain names (your main domain and the wildcard), two different entries with the same domain name _acme-challenge are required, not only one.
Two of these blue lines.
Should look like
but with two lines.
