DNS problem: NXDOMAIN looking up A for go.**.se.well-known
This is the first time this domain fails to renew, haven’t changed any DNS settings.
Why does it say .well-known in the A record?
The web server is sending a redirect to http://go.sableline.se.well-known/something
or https://go.sableline.se.well-known/something
If it’s Apache, check for something like “Redirect / https://go.sableline.se
” and add a “/
” to the end.
Thanks, the redirect was probably it - seems like another upgrade had commented out the correct line with / at the end and added a new line without / at the end.
EDIT: All good, works again. Thanks for the help!
