DNS problem: NXDOMAIN looking up A for testnklab.com
Hi everyone,
I have next error when try to create certificate on CentOS 8(WepApp is nginx) by command:
certbot certonly --authenticator manual -d testnklab.com
Error:
http://testnklab.com/.well-known/acme-challenge/X30PPrRFwi_n_xqttB-erFg2ZwlvktDBN-yNnB86688
Press Enter to Continue
Domain: testnklab.com
Type: dns
Detail: DNS problem: NXDOMAIN looking up A for testnklab.com - check that a DNS record exists for this domain; DNS problem: NXDOMAIN looking up AAAA for testnklab.com - check that a DNS record exists for this domain
Hint: The Certificate Authority failed to verify the manually created challenge files. Ensure that you created these in the correct location.
Questions:
  1. How to fix the error?
testnklab.com needs to be a real, registered domain name which points to your server.
Since this is not the case, you cannot demonstrate control of the domain, and Let's Encrypt won't issue a certificate for it.
