DNS problem: networking error looking up A for
Hello everyone,
I installed LetsEncrypt (specifically certbot-auto) on a system to work with the latest ISPConfig 3.1b2.
However, whenever I try to create a cert, I get an error like this:
DNS problem: networking error looking up A for kirito.ennabe.de
The DNS works fine, however, since I can access the server without any problems using the exact same domain.
Here’s the complete error message:
`Failed authorization procedure. kirito.ennabe.de (tls-sni-01): urn:acme:error:connection :: The server could not connect to the client to verify the domain :: DNS problem: networking error looking up A for kirito.ennabe.de
    Domain: kirito.ennabe.de
    Type: connection
    Detail: DNS problem: networking error looking up A for
    kirito.ennabe.de
Can you help me with this issue?
Thank you in advance
Kind Regards
Sascha Schroeder
There is another topic on this issue as well at Cannot lookup A record for domain.
There was a problem with the validation service that has been resolved. Things are working again.
https://letsencrypt.status.io/
Hi. Sorry to piggyback on the post, but I was facing a similar issue. My DNS records are configured to use CNAME. Is it mandatory to have an A record for the domain? Thanks.
CNAME’s work, as long as the target has an A record of course.
So A records are a must? CNAME is optional? I tried to have both CNAME and and A record, but GoDaddy did not allow that.
Currently all my subdomains have only CNAME records. So looks like I have to change them all to A. Hope they allow multiple A records pointing to the same IP address.
No, you can have CNAMEs for your subdomains, they just have to be pointing at a domain that does have an A record. It sounds like you have the same setup that I do of an A record for the base domain with the subdomains CNAMEed to that which is correct and works.
Ah ha! The problem is that the primary domain and these subdomains are on different servers.
