DNS problem: looking up CAA for www.wdsd.org: DNSSEC: Bogus
My domain is:wdsd.org
I ran this command:certbot -v renew --cert-name wdsd.org
Processing /etc/letsencrypt/renewal/wdsd.org.conf
Certificate is due for renewal, auto-renewing...
Renewing an existing certificate for wdsd.org and www.wdsd.org
http-01 challenge for www.wdsd.org
Challenge failed for domain www.wdsd.org
Domain: www.wdsd.org
Type: dns
Detail: DNS problem: looking up CAA for www.wdsd.org: DNSSEC: Bogus
Failed to renew certificate wdsd.org with error: Some challenges have failed.
/etc/letsencrypt/live/wdsd.org/fullchain.pem (failure)
My web server is (include version): Apache 2.4
The operating system my web server runs on is (include version): Ubuntu 22.04
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot):certbot 1.21.0
That says it all. The Let's Encrypt servers are looking for the CAA record in your DNS and getting a faulty response from your DNS system.
It can be reproduced using this tool
https://unboundtest.com/m/CAA/www.wdsd.org/YOK2P7LD
I am not skilled enough with DNS to suggest exactly how to correct this. I could only suggest talking with your DNS provider.
There are other more experienced DNS volunteers here and I already see one starting to type so ...
Your DNS server, while giving a valid answer for the A record, doesn't correctly return that there isn't a result for other record types, like AAAA or CAA. You need to fix your DNS so that your domain name works before you can get a certificate (and before users can reliably get to your domain name).
Just how to fix it depends a lot on the DNS software in use, but pretty anything even halfway-recent should be handling it automatically. But it looks like you might be using Network Solutions for your DNS, which has had a lot of complaints by people around here since it seems like they don't actually know how to run a DNS server.
Here's a somewhat-recent thread about it:
More [of the same] info:
Let's Debug (letsdebug.net)
