Detail: No valid IP addresses found for bbb.univ-fcomte.fr
I have setup a A name 'n PTR for my domain.
When I check on an OVH server I get :
nslookup bbb.univ-fcomte.fr
Server: 127.0.0.1
Address: 127.0.0.1#53
Non-authoritative answer:
bbb.univ-fcomte.fr canonical name = pres-115.univ-fcomte.fr.
Address: 194.57.76.115
Ant ptr :
nslookup
set type=PTR
194.57.76.115
Server: 213.186.33.99
Address: 213.186.33.99#53
115.76.57.194.in-addr.arpa name = bbb.univ-fcomte.fr.
But I get always error :
certbot --webroot -w /var/www/bigbluebutton-default/ -d bbb.univ-fcomte.fr certonly
http-01 challenge for bbb.univ-fcomte.fr
Using the webroot path /var/www/bigbluebutton-default for all unmatched domains.
Waiting for verification…
Failed authorization procedure. bbb.univ-fcomte.fr (http-01): urn:ietf:params:acme:error:dns :: No valid IP addresses found for bbb.univ-fcomte.fr
Someone have an idea ?
Thanks
Hi @GeraldGeniaut
there is a check of your domain - one hour old - https://check-your-website.server-daten.de/?q=bbb.univ-fcomte.fr
There is no problem visible. But checking your three name servers manual:
One has a timeout
One has the NXDOMAIN
One has the ip address.
Checked with Unboundtest - https://unboundtest.com/m/A/bbb.univ-fcomte.fr/UAU77AFC - the same:
Response:
;; opcode: QUERY, status: NXDOMAIN, id: 25305
May be you have to wait, because your name servers are buggy.
PS: Checking the main domain - https://check-your-website.server-daten.de/?q=univ-fcomte.fr
X Fatal error: Nameservers mit different SOA Serial Numbers
The zones have different informations.
I will check this. Thanks !
see you
