Detail: DNS problem: NXDOMAIN looking up A for caop-server.calcomp.com.tw
First of all, I am setting up a gitlab sever in my office, I encounted a DNS problem while installing certbot.
My domain is: caop-server.calcomp.com.tw
I ran this command: sudo certbot certonly --standalone
sean@opsw-server:~$ sudo certbot certonly --standalone
Please enter the domain name(s) you would like on your certificate (comma and/or
space separated) (Enter 'c' to cancel): caop-server.calcomp.com.tw
Requesting a certificate for caop-server.calcomp.com.tw
Could not bind TCP port 80 because it is already in use by another process on
this system (such as a web server). Please stop the program in question and then
try again.
(R)etry/(C)ancel: R
Certbot failed to authenticate some domains (authenticator: standalone). The Cer tificate Authority reported these problems:
Domain: caop-server.calcomp.com.tw
Type: dns
Detail: DNS problem: NXDOMAIN looking up A for caop-server.calcomp.com.tw - check that a DNS record exists for this domain; DNS problem: NXDOMAIN looking up AAAA for caop-server.calcomp.com.tw - check that a DNS record exists for this domain
My web server is (include version): Nginx for Gitlab
snap 2.59.4
snapd 2.59.4
series 16
ubuntu 22.04
kernel 5.15.0-73-generic
I am a new guy for programming, thanks for your help.
This error message seems entirely straightforward; are you having trouble understanding it? It's saying that there are no DNS records for the domain in question, which is what I'm finding as well. You need to make sure those are present and pointing to the server you're using.
Also:
Why use --standalone?
What is using port 80?
Using this online tool https://check-host.net/ easily demonstrates @danb35's comment in post #2 above.
The Permanent link to this check report shows Results of Not found.
Is that server accessible from the public internet?
Yes, I can not really understand that since I am not familiar with how DNS/Server works.
I have check with our company's MIS member, they are sure the DNS & the domain name "caop-server.calcomp.com.tw" are correct.
Thanks for your reply
I just follow the instructions to use --standalone, is there others I can use?. Apache2 use the port, I terminated it and re-try.
Thanks for your replay.
Thanks, I saw it. should I ask our company's MIS to make "caop-server.calcomp.com.tw" searchable on the website?
No, it is from internal network. is it the problem from internal network?
When using HTTP validation, the name must be resolvable, and reachable, from the Internet.
If that is not possible, then you can't use HTTP validation.
And must use DNS validation method.
See also
When you get a certificate from Let’s Encrypt, our servers validate that you control the domain names in that certificate using “challenges,” as defined by the ACME standard.
In order to "validate that you control the domain names in that [requested] certificate", the certificate authority's servers (outside of your network!) must be able to see that you can make a requested change related to those names. That is the proof that you actually control those names.
Thanks, @schoen, I understand.
