Default Apache Location?
Hi, I use a service that puts my apache configuration in /etc/zpanel/configs/http-vhosts.conf - so when I try to use certbot-auto, it looks in for vhosts in sites-available, which yields incorrect data.
Is there any way around this?
If you want certbot to automatically read / configure apache then no, as far as I’m aware.
You can still use certbot to obtain the certs for any domain by specifying the domains you want on the command line though and using webroot.
