Hello,
Let’s Encrypt is a great software and one that will help so much for web security. thank you for the entire community and developers involved.
I have done a search for my question but have not found something clear for me.
I prefer using the apache plugin rather than the webroot, to benefit from its automation.
Due to many Control Panels using custom vhost conf locations, is there a way to specify where the apache plugin should look for those files?
I have confirmed that the plugin finds the vhost.conf files in the sites-available location, however, some control panels save this configuration in other directories and reference then in the main apache conf, either under the mod-enabled directory, or to various locations as /home/user/etc…,
can I pass an argument or specify the location of these vhost files to let’s encrypt?
Am i misunderstanding how the plugin finds the enabled servernames?
