Vidyut
February 16, 2019, 11:20am
62
In sites-enabled I have one file with - all of them in one file:
fastcgi_cache_path /var/run/nginx-cache levels=1:2 keys_zone=WORDPRESS:100m inactive=60m;
fastcgi_cache_key “$scheme$request_method$host$request_uri”;
fastcgi_cache_use_stale error timeout invalid_header http_500;
fastcgi_ignore_headers Cache-Control Expires Set-Cookie;
listen 80;
listen [::]:80;
listen 443 default ssl http2;
listen [::]:443 default ssl http2 ipv6only=on;
server_name .aamjanata.com wide-aware.com ;
root /var/www/aj;
include global/wordpress-fastcgi.conf;
listen 80;
listen [::]:80;
listen 443 ssl http2;
listen [::]:443 ssl http2;
server_name .digitalindia.watch;
root /var/www/diwdru;
include global/diw1.conf;
listen 80;
listen [::]:80;
server_name .fekle.in;
root /var/www/fl;
listen 80;
listen [::]:80;
server_name .nisarga.info;
root /var/www/ni;
listen 80;
listen [::]:80;
server_name .vidyut.net;
root /var/www/vn;
listen 80;
listen [::]:80;
server_name .vidyut.info;
root /var/www/vin;
listen 80;
listen [::]:80;
server_name .homeschoolingindia.in;
root /var/www/hs;
listen 80;
listen [::]:80;
server_name india.aamjanata.com ;
ssl_certificate /etc/letsencrypt/live/vidyut.net-0001/fullchain.pem;
ssl_certificate_key /etc/letsencrypt/live/vidyut.net-0001/privkey.pem;
root /var/www/map;
add_header Strict-Transport-Security “max-age=31536000”;
add_header Alternate-Protocol 443:npn-spdy/3;
ssl_protocols SSLv3 TLSv1 TLSv1.1 TLSv1.2;
ssl_prefer_server_ciphers on;
ssl_ciphers !aNULL:!LOW:!MD5:!EXP:RC4:AES256:3DES:AES128:SEED:CAMELLIA;
resolver 8.8.8.8 8.8.4.4 208.67.222.222 208.67.220.220 valid=300s;
resolver_timeout 10s;
ssl_stapling on;
ssl_stapling_verify on;
ssl_trusted_certificate /etc/nginx/ssl/stapling.crt;
charset utf-8;
override_charset on;
location /platform {
fastcgi_param QUERY_STRING $query_string;
fastcgi_param REQUEST_METHOD $request_method;
fastcgi_param CONTENT_TYPE $content_type;
fastcgi_param CONTENT_LENGTH $content_length;
fastcgi_split_path_info ^(/platform/)(.*)$;
fastcgi_param SCRIPT_FILENAME $document_root/platform/httpdocs/index.php;
fastcgi_param SCRIPT_NAME $fastcgi_script_name;
fastcgi_param PATH_INFO $fastcgi_path_info;
fastcgi_param PATH_TRANSLATED $document_root$fastcgi_path_info;
fastcgi_param REQUEST_URI $request_uri;
fastcgi_param DOCUMENT_URI $document_uri;
fastcgi_param DOCUMENT_ROOT $document_root;
fastcgi_param SERVER_PROTOCOL $server_protocol;
fastcgi_param GATEWAY_INTERFACE CGI/1.1;
fastcgi_param SERVER_SOFTWARE nginx/$nginx_version;
fastcgi_param REMOTE_ADDR $remote_addr;
fastcgi_param REMOTE_PORT $remote_port;
fastcgi_param SERVER_ADDR $server_addr;
fastcgi_param SERVER_PORT $server_port;
fastcgi_param SERVER_NAME $server_name;
fastcgi_param HTTPS $https;
fastcgi_pass php;
try_files $uri /index.html;
listen 80;
listen [::]:80;
server_name .aadhaar.fail;
root /var/www/af;
listen 80;
listen [::]:80;
server_name .aamjanata.in;
root /var/www/ajin;
Vidyut
February 16, 2019, 11:21am
63
Included file contains
ssl_protocols TLSv1 TLSv1.1 TLSv1.2 TLSv1.3;
ssl_ciphers ‘ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-AES256-GCM-SHA384:DHE-RSA-AES128-GCM-SHA256:DHE-DSS-AES128-GCM-SHA256:kEDH+AESGCM:ECDHE-RSA-AES128-SHA256:ECDHE-ECDSA-AES128-SHA256:ECDHE-RSA-AES128-SHA:ECDHE-ECDSA-AES128-SHA:ECDHE-RSA-AES256-SHA384:ECDHE-ECDSA-AES256-SHA384:ECDHE-RSA-AES256-SHA:ECDHE-ECDSA-AES256-SHA:DHE-RSA-AES128-SHA256:DHE-RSA-AES128-SHA:DHE-DSS-AES128-SHA256:DHE-RSA-AES256-SHA256:DHE-DSS-AES256-SHA:DHE-RSA-AES256-SHA:AES128-GCM-SHA256:AES256-GCM-SHA384:AES128-SHA256:AES256-SHA256:AES128-SHA:AES256-SHA:AES:CAMELLIA:DES-CBC3-SHA:!aNULL:!eNULL:!EXPORT:!DES:!RC4:!MD5:!PSK:!aECDH:!EDH-DSS-DES-CBC3-SHA:!EDH-RSA-DES-CBC3-SHA:!KRB5-DES-CBC3-SHA’;
ssl_dhparam /etc/nginx/ssl/dhparams.pem;
ssl_ecdh_curve X25519:P-256:P-384:P-521;
ssl_stapling on;
set $skip_cache 0;
if ($request_method = POST) {
set $skip_cache 1;
if ($query_string != "") {
set $skip_cache 1;
if ($request_uri ~* "/wp-admin/|/xmlrpc.php|wp-.*.php|/feed/|index.php|sitemap(_index)?.xml") {
set $skip_cache 1;
if ($http_cookie ~* "comment_author|wordpress_[a-f0-9]+|wp-postpass|wordpress_no_cache|wordpress_logged_in") {
set $skip_cache 1;
rewrite ^/wp-content/uploads/knewsimages/(.*).(jpg|jpeg|gif|png)$ /wp-content/plugins/knews/direct/track.php?img=$1 break;
try_files $uri $uri/ /index.php?$args;
location ~ /.well-known/acme-challenge {
allow all;
default_type text/plain;
location ~ \.php$ {
try_files $uri /index.php;
include fastcgi_params;
fastcgi_pass php;
fastcgi_buffers 8 128k;
fastcgi_buffer_size 256k;
fastcgi_cache_bypass $skip_cache;
fastcgi_no_cache $skip_cache;
fastcgi_read_timeout 300;
fastcgi_cache WORDPRESS;
fastcgi_cache_valid 60m;
add_header X-Cache $upstream_cache_status;
location ~ /purge(/.*) {
location ~* ^.+\.(ogg|ogv|svg|svgz|eot|otf|woff|mp4|ttf|rss|atom|gif|ico|zip|tgz|gz|rar|bz2|doc|xls|exe|ppt|tar|mid|midi|wav|bmp|rtf|css|js)$ {
access_log off; log_not_found off; expires max;
fastcgi_hide_header “Set-Cookie”;
location ~* ^.+.(png|jpe?g)$ {
add_header Vary Accept;
access_log off; error_log off; expires max;
try_files $uri$webp_suffix $uri =404;
rg305
February 16, 2019, 11:22am
64
Are those names all actually prepended with "." ?
Vidyut
February 16, 2019, 11:23am
65
yes. to serve domain and subdomains. Is that a problem?
rg305
February 16, 2019, 11:25am
66
I speak to dozens of people - please don't make me look for that info...
What does it say?
Vidyut
February 16, 2019, 11:29am
67
sorry. default_type text/plain;
- adding it to that post also.
rg305
February 16, 2019, 11:32am
68
OK I find nothing obviously wrong with the setup…
Looking closer at the error message(s)…
They all contain “Timeout during connect (likely firewall problem)”
Perhaps we are now facing a problem outside your system - Like: Firewall/IPS/Geo-Location blocking
Vidyut
February 16, 2019, 11:34am
69
It is a digitalocean droplet. No idea if they block any traffic, but I certainly haven’t blocked any. No firewall, no IPs, no geo-location, etc
If DO were blocking, we’d see a lot more of these problems by now.
Vidyut
February 16, 2019, 11:36am
71
I could try switching “.example.com” type server names to the longer, but same “example.com and *.example.com” if you think it matters. Nginx accepts this configuration - letsencrypt also has so far. Sites are served and functioning perfectly well. http://nginx.org/en/docs/http/server_names.html (see “wildcard” section)
This has been the configuration for years and certificates have been updating smoothly so far.
rg305
February 16, 2019, 11:39am
72
Not with “*” - match the names in the cert.
like:
server_name digitalindia.watch www.digitalindia.watch;
or separately like:
server_name digitalindia.watch;
server_name www.digitalindia.watch;
rg305
February 16, 2019, 11:41am
73
What I don’t get is why only 10 fetches fail (out of 21 names on the cert):
Detail: Fetching http://vidyut.net/.well-known/acme-challenge/mtAlSi9QZUHAwxc5R16Io_nAecrv_7ISEfoDjA515tk: Timeout during connect (likely firewall problem)
Detail: Fetching http://www.vidyut.info/.well-known/acme-challenge/wfYJ4d9tFgk3D0r40fm9XDyUzLp4mahjtzLIx7k-HCs: Timeout during connect (likely firewall problem)
Detail: Fetching http://www.digitalindia.watch/.well-known/acme-challenge/whEiWqXVvwLPvoTXs5zb-IdEL9csQp0CtrLyWwSzQgU: Timeout during connect (likely firewall problem)
Detail: Fetching http://www.homeschoolingindia.in/.well-known/acme-challenge/KNvSiSkCIDM6Qes-wTnusT6g8X-q1VdNQBew0mftIOM: Timeout during connect (likely firewall problem)
Detail: Fetching http://www.wide-aware.com/.well-known/acme-challenge/tAbsTbJ9KPYaDjjdEebsXrc6IhaEVVduO7xasAXwQiQ: Timeout during connect (likely firewall problem)
Detail: Fetching http://nisarga.info/.well-known/acme-challenge/F-9Dq4_G1vSdk91DFNKEN7F_oIKLZxaq2_N2_Cx7cFM: Timeout during connect (likely firewall problem)
Detail: Fetching http://www.aamjanata.in/.well-known/acme-challenge/wypFslfVw8dBZTtYuI4kW1esWkikEDTknBX8L1ZCKjA: Timeout during connect (likely firewall problem)
Detail: Fetching http://digitalindia.watch/.well-known/acme-challenge/zSQHYe7p9kjcl5O572-X9TVJZUmjBm4Qu2cEC07NbRo: Timeout during connect (likely firewall problem)
Detail: Fetching http://homeschoolingindia.in/.well-known/acme-challenge/K2uZfkwTvry2U1b7jEeQodIwEGFOATIEmprZGBgX8rU: Timeout during connect (likely firewall problem)
Detail: Fetching http://www.aadhaar.fail/.well-known/acme-challenge/s-LUeRrJpNR3PVPjuohuv7_GFpBVql30clShAtwCPUY: Timeout during connect (likely firewall problem)
DNS:aadhaar.fail
DNS:aamjanata.com
DNS:aamjanata.in
DNS:digitalindia.watch
DNS:fekle.in
DNS:homeschoolingindia.in
DNS:india.aamjanata.com
DNS:nisarga.info
DNS:vidyut.info
DNS:vidyut.net
DNS:wide-aware.com
DNS:www.aadhaar.fail
DNS:www.aamjanata.com
DNS:www.aamjanata.in
DNS:www.digitalindia.watch
DNS:www.fekle.in
DNS:www.homeschoolingindia.in
DNS:www.nisarga.info
DNS:www.vidyut.info
DNS:www.vidyut.net
DNS:www.wide-aware.com
Vidyut
February 16, 2019, 11:48am
75
First thing I'd done was checked error logs for if the server was under stress or anything. Server normal. No timeouts (other than some php plugin related ones - irrelevant to this and timings don't match) or ANY errors related to .well-known
I have to go out for two hours right now, but do you think it is worth activating access log for .well-known when I return? To see if the requests are being made at all?
I don't think this is a DNS issue. Different files fail to fetch - not same ones. Plus sites are and have been working fine for years.
rg305
February 16, 2019, 11:51am
76
Timeout it network.
Why? I don’t know.
You can reach a test file.
I can reach a test file.
LE (staging) can’t reach their test file.
Today production is only using HTTP-01 (like staging is with --dry-run).
We can try to force a renewal and that will be done via HTTP-01.
Try this only once:
certbot renew --installer null --force-renewal -vv
[and show the output]
Vidyut
February 16, 2019, 11:55am
77
rg305:
Looooooong output (as usual) but summary is:
/etc/letsencrypt/live/vidyut.info-0001/fullchain.pem (success)
no renewal failures
Still need log for debugging? Can post.
rg305
February 16, 2019, 11:56am
78
As long as it shows HTTP-01 (which it should) that part is OK.
I don’t understand why the production systems can reach your server and yet the staging systems can’t…
rg305
February 16, 2019, 11:58am
79
The only thing to check (which has now been reset to 60 days from today) is that it can renew automatically on its’ own.
Vidyut
80
Happy to help debug in any way, but this means that when the time comes, actual renewal will work and I can breathe easy?
Have to head out right now, but will return in 2 hours.
rg305
February 16, 2019, 12:00pm
81
Vidyut:
I can breathe easy?
Yes, we can continue in 61 days (if it fails to renew automatically).
