That looks wrecked:
- There are duplicate sections for
Directory /var/www/masihhits.com/html
- There is a private cert key file but no public cert file used
- There is an HTTP section there that is entirely not needed
[and it is wrapped within an IfModule for SSL - that makes less than no sense] - ReWriteEngine is turned on and then… not used
Perhaps we should have a look at the file that “created” this mess…
sudo cat /etc/apache2/sites-enabled/masihhits.com.conf
[I suspect it has some of the same problems - that were passed on]
ok, ill fix it, thanks
