Is that means the IP 181.120.215.171 has more than one server behind the router? (And port 80 is forwarded to another server in the same subnet?)
P.S
Are both server accessible to each other? (Interconnected..in the same subnet?)
Just trying to make sure....
Thank you
Well i can now generate the certificate, changing the forwarding of the router momentarily. This folder was generate:
How i use this file?
Thank,
David
Yep, now the certificate is created:
https://transparencyreport.google.com/https/certificates?cert_search_auth=&cert_search_cert=&cert_search=include_expired:false;include_subdomains:false;domain:mail.criterion.com.py&lu=cert_search
Now something like
# file /etc/postfix/main.cf
smtpd_tls_cert_file= /etc/letsencrypt/live/domainname/fullchain.pem
smtpd_tls_key_file= /etc/letsencrypt/live/domainname/privkey.pem
# File /etc/dovecot/conf.d/10-ssl.conf
ssl = yes
ssl_cert = </etc/letsencrypt/live/domainname/fullchain.pem
ssl_key = </etc/letsencrypt/live/domainname/privkey.pem
should work. Don’t forget to restart both.
system
Closed
24
