Create certificate Error
Hi there,
I ran the command you suggested with an extra ‘-‘ for the webroot option
certbot --nginx --agree-tos --redirect --hsts --staple-ocsp --email serveradmin@jwservices.co.nz --webroot -w /var/www/html -d www.jwservices.co.nz
/var/www/html does not exist or is not a directory
This machine is setup as a proxy only and has no websites on it, it only redirects to the machines with the site on it.
Fixed the post for correctness :slight_smile:
This is found several times within your code:
    root /var/www/html;
That directory doesn't exist?
Hi there,
That code i added after your suggestion earlier in this thread
I thought you would ensure that it worked before adding it.
And if I recall correctly, I merely reused one of the roots found in one of your server blocks.
I did not make that path up.
Had I, I would have asked you to create a new dedicated path for only challenge requests.
Review your code and the posts above.
In review, I think we may have gotten that "default code" from @_az
Who probably should have mentioned that you needed to validate it or adjust it to fit your needs - it was only being shown as a demonstrative example.
So...
The fix is to create that path or change all occurrences to an actual path on your system.
Hi all,
I have decided to shut down all my public facing servers mentioned in this thread.
thanks for your time.
