Cpanel reseller letsencrypt not enabled - manual set up issues
My domain is: yaadev.com
I ran this command: getssl yaadev.com
It produced this output: yaadev.com: Certificate on remote domain does not match, ignoring remote certificate
My web server is (include version): httpd (2.4.29 (cPanel))
The operating system my web server runs on is (include version): CLOUDLINUX 6.9 standard
My hosting provider, if applicable, is: Greengeeks.com
I can login to a root shell on my machine (yes or no, or I don’t know): no
I’m using a control panel to manage my site (no, or provide the name and version of the control panel): cpanel reseller
I have successfully manually installed a certificate using dns verification via sslforfree.com for one of the domains. I have a dedicated IP for my reseller account that is shared by 33 domains.
The certificates are created on my local machine successfully but I run into the issue when getssl tries to copy them and install on the server. I have copied the cpanel additional script to the server and set.
RELOAD_CMD="${HOME}/cpanel_cert_upload yaadev.com"
I do not know where to go next…
https://www.greengeeks.com/kb/?s=ssl
sorry I was not clear, it is a reseller account with 35 individual accounts under it with one domain each. The reseller account has a dedicated IP that is shared by the individual accounts. Each account has its own cpanel interface and home directory.
