eastshockey.org.au
Renew Certificates which is set to auto but fails
Could not issue an SSL/TLS certificate for eastshockey.org.au
Details
Could not issue a Let's Encrypt SSL/TLS certificate for eastshockey.org.au .
The authorization token is not available at http://eastshockey.org.au/.well-known/acme-challenge/ath0TxWiyUwNpWIUZoddrkPuTjrjzSDfp8NtlTune3Y.
To resolve the issue, make sure that the token file can be downloaded via the above URL.
IIS
Windows Server
Plesk
QUESTION
I can see what is happening - the token is being created, but in a folder that requires HTTPS.
I did turn on HTTP to HTTPS redirect, but this seems its just for the folder content and NOT files.
What Config change do I need to make so that the file is available on HTTP or get the redirect to HTTPS work?
Running Windows Server IIS with Plesh desktop
Cheers
Philip
