My domain is:Botric.tv
I ran this command:sudo certbot --apache
It produced this output:Saving debug log to /var/log/letsencrypt/letsencrypt.log
Could not find ssl_module; not disabling session tickets.
1: botric.tv
2: www.botric.tv
blank to select all options shown (Enter 'c' to cancel): 1,2
requested (ref: /etc/letsencrypt/renewal/www.botric.tv.conf)
It contains these names: www.botric.tv
You requested these names for the new certificate: botric.tv, www.botric.tv.
certificate?
(E)xpand/(C)ancel: e
Renewing an existing certificate for botric.tv and www.botric.tv
Certificate is saved at: /etc/letsencrypt/live/www.botric.tv/fullchain.pem
Key is saved at: /etc/letsencrypt/live/www.botric.tv/privkey.pem
This certificate expires on 2021-11-07.
Certbot has set up a scheduled task to automatically renew this certificate in the background.
Deploying certificate
Could not install certificate
NEXT STEPS:
- The certificate was saved, but could not be installed (installer: apache). After fixing the error shown below, try installing it again by running:
certbot install --cert-name www.botric.tv
Could not find ssl_module; not installing certificate.
Ask for help or search for solutions at https://community.letsencrypt.org. See the logfile /var/log/letsencrypt/letsencrypt.log or re-run Certbot with -v for more details
My web server is (include version): Apache/2.4.37 (centos)
The operating system my web server runs on is (include version):centOS 8.4.2105.0-3.el8
My hosting provider, if applicable, is:N/A
or certbot-auto --version
if you're using Certbot):certbot 1.18.0
