Even so, it's impossible to connect to 172.10.235.115 on port 80 or 443, also from my end. Time out.
Something very strange is going on:
osiris@desktop ~ $ ping checkphish.org
PING checkphish.org (172.10.235.115) 56(84) bytes of data.
64 bytes from 172-10-235-115.lightspeed.sntcca.sbcglobal.net (172.10.235.115): icmp_seq=1 ttl=50 time=182 ms
64 bytes from 172-10-235-115.lightspeed.sntcca.sbcglobal.net (172.10.235.115): icmp_seq=1 ttl=50 time=182 ms (DUP!)
64 bytes from 172-10-235-115.lightspeed.sntcca.sbcglobal.net (172.10.235.115): icmp_seq=2 ttl=50 time=181 ms
64 bytes from 172-10-235-115.lightspeed.sntcca.sbcglobal.net (172.10.235.115): icmp_seq=2 ttl=50 time=182 ms (DUP!)
64 bytes from 172-10-235-115.lightspeed.sntcca.sbcglobal.net (172.10.235.115): icmp_seq=3 ttl=50 time=181 ms
64 bytes from 172-10-235-115.lightspeed.sntcca.sbcglobal.net (172.10.235.115): icmp_seq=3 ttl=50 time=182 ms (DUP!)
64 bytes from 172-10-235-115.lightspeed.sntcca.sbcglobal.net (172.10.235.115): icmp_seq=4 ttl=50 time=181 ms
64 bytes from 172-10-235-115.lightspeed.sntcca.sbcglobal.net (172.10.235.115): icmp_seq=4 ttl=50 time=182 ms (DUP!)
64 bytes from 172-10-235-115.lightspeed.sntcca.sbcglobal.net (172.10.235.115): icmp_seq=5 ttl=50 time=182 ms
64 bytes from 172-10-235-115.lightspeed.sntcca.sbcglobal.net (172.10.235.115): icmp_seq=5 ttl=50 time=182 ms (DUP!)
^C64 bytes from 172.10.235.115: icmp_seq=6 ttl=50 time=182 ms
--- checkphish.org ping statistics ---
6 packets transmitted, 6 received, +5 duplicates, 0% packet loss, time 7985ms
rtt min/avg/max/mdev = 181.756/182.182/182.504/0.352 ms, pipe 2
osiris@desktop ~ $ traceroute checkphish.org
traceroute to checkphish.org (172.10.235.115), 30 hops max, 60 byte packets
1 router.local 0.463 ms 0.466 ms 0.717 ms
2 lo0.dr13.d12.xs4all.net (194.109.5.212) 22.327 ms 22.320 ms 22.310 ms
3 0.ae23.xr4.1d12.xs4all.net (194.109.7.17) 15.934 ms 0.ae23.xr3.3d12.xs4all.net (194.109.7.53) 15.948 ms 0.ae23.xr4.1d12.xs4all.net (194.109.7.17) 15.939 ms
4 asd2-rou-1044.NL.eurorings.net (134.222.97.17) 15.929 ms asd2-rou-1043.NL.eurorings.net (134.222.93.144) 23.394 ms 23.385 ms
5 rt2-rou-1022.NL.eurorings.net (134.222.48.209) 23.358 ms 23.350 ms rt2-rou-1022.NL.eurorings.net (134.222.48.211) 23.339 ms
6 nyk-s1-rou-1021.US.eurorings.net (134.222.48.1) 108.273 ms 109.630 ms ldn-s2-rou-1101.UK.eurorings.net (134.222.48.200) 28.284 ms
7 nyk-s2-rou-1021.US.eurorings.net (134.222.48.92) 100.231 ms 94.063 ms nyk-s2-rou-1021.US.eurorings.net (134.222.48.35) 94.959 ms
8 12.250.255.9 (12.250.255.9) 150.034 ms 150.044 ms 131.155 ms
9 cr1.n54ny.ip.att.net (12.122.105.42) 181.076 ms 181.794 ms 179.535 ms
10 cr2.cgcil.ip.att.net (12.122.1.2) 182.982 ms 182.972 ms 186.766 ms
11 cr1.cgcil.ip.att.net (12.122.2.53) 189.538 ms 189.528 ms 186.042 ms
12 cr1.sffca.ip.att.net (12.122.4.121) 187.287 ms 182.232 ms 182.242 ms
13 12.122.137.245 (12.122.137.245) 187.964 ms 184.753 ms 187.943 ms
14 * * *
15 * * *
16 71.148.149.45 (71.148.149.45) 189.255 ms 187.069 ms 187.080 ms
17 172-10-235-115.lightspeed.sntcca.sbcglobal.net (172.10.235.115) 187.962 ms 188.564 ms 189.124 ms
osiris@desktop ~ $ sudo traceroute -T -p 80 checkphish.org
1 router.local 0.553 ms 0.630 ms 0.915 ms
2 lo0.dr13.d12.xs4all.net (194.109.5.212) 8.506 ms 8.815 ms 9.936 ms
3 0.ae23.xr4.1d12.xs4all.net (194.109.7.17) 9.931 ms 0.ae23.xr3.3d12.xs4all.net (194.109.7.53) 10.103 ms 10.262 ms
4 asd2-rou-1043.NL.eurorings.net (134.222.93.144) 11.142 ms 11.150 ms asd2-rou-1044.NL.eurorings.net (134.222.97.17) 11.162 ms
5 rt2-rou-1022.NL.eurorings.net (134.222.48.211) 14.493 ms rt2-rou-1022.NL.eurorings.net (134.222.48.209) 16.567 ms rt2-rou-1022.NL.eurorings.net (134.222.48.211) 15.901 ms
6 nyk-s1-rou-1021.US.eurorings.net (134.222.48.1) 126.921 ms 126.436 ms 126.889 ms
7 nyk-s2-rou-1021.US.eurorings.net (134.222.48.35) 99.252 ms 91.649 ms 93.208 ms
8 12.250.255.9 (12.250.255.9) 106.499 ms 122.536 ms 113.756 ms
9 cr1.n54ny.ip.att.net (12.122.105.42) 186.947 ms 189.585 ms 189.585 ms
10 cr2.cgcil.ip.att.net (12.122.1.2) 188.926 ms 188.016 ms 187.939 ms
11 cr1.cgcil.ip.att.net (12.122.2.53) 188.329 ms 188.285 ms 186.606 ms
12 cr1.sffca.ip.att.net (12.122.4.121) 185.850 ms 184.270 ms 183.967 ms
13 12.122.137.245 (12.122.137.245) 187.039 ms 187.881 ms 188.013 ms
14 * * *
15 * * *
16 71.148.149.45 (71.148.149.45) 187.699 ms 188.550 ms 188.413 ms
17 172-10-235-115.lightspeed.sntcca.sbcglobal.net (172.10.235.115) 190.364 ms 189.252 ms 190.275 ms
18 * * *
19 * * *
20 * * *
21 * * *
22 * * *
23 * * *
24 * * *
25 * * *
26 * * *
27 * * *
28 * * *
29 * * *
30 * * *
osiris@desktop ~ $
You can see three things:
Duplicate ICMP replies are send on ping..?
Normal traceroute seems to work fine;
When trying to trace the route of TCP port 80 packets, it looks if it ends up at your server, but the traceroute doesn't stop?
