Correct zName not found for TLS SNI challenge
okay that one actually hurts. didnt know that.
Here is what I get on the command line:
root@65shelbycobra:/home/ubuntu/Downloads/letsencrypt# ./letsencrypt-auto renew
Updating letsencrypt and virtual environment dependencies…
Running with virtualenv: /root/.local/share/letsencrypt/bin/letsencrypt renew
Processing /etc/letsencrypt/renewal/65shelbycobra.com.conf
2016-03-01 20:20:18,340:WARNING:letsencrypt.cli:Attempting to renew cert from /etc/letsencrypt/renewal/65shelbycobra.com.conf produced an unexpected error: Failed authorization procedure. 65shelbycobra.com (tls-sni-01): urn:acme:error:unauthorized :: The client lacks sufficient authorization :: Correct zName not found for TLS SNI challenge. Found ‘65shelbycobra.com’. Skipping.
/etc/letsencrypt/live/65shelbycobra.com/fullchain.pem (failure)
    Domain: 65shelbycobra.com
    Detail: Correct zName not found for TLS SNI challenge. Found
    65shelbycobra.com
Logs from latest try to renew
Detail: Correct zName not found for TLS SNI challenge. Found ‘65shelbycobra.com
To fix these errors, please make sure that your domain name was entered correctly and the DNS A record(s) for that domain contain(s) the right IP address.
2016-03-01 20:20:18,161:INFO:letsencrypt.auth_handler:Cleaning up challenges
2016-03-01 20:20:18,341:DEBUG:letsencrypt.cli:Traceback was:
File “/root/.local/share/letsencrypt/local/lib/python2.7/site-packages/letsencrypt/cli.py”, line 1017, in renew
obtain_cert(lineage_config, plugins, renewal_candidate)
File “/root/.local/share/letsencrypt/local/lib/python2.7/site-packages/letsencrypt/cli.py”, line 706, in obtain_cert
_, action = _auth_from_domains(le_client, config, domains, lineage)
File “/root/.local/share/letsencrypt/local/lib/python2.7/site-packages/letsencrypt/cli.py”, line 457, in _auth_from_domains
new_certr, new_chain, new_key, _ = le_client.obtain_certificate(domains)
File “/root/.local/share/letsencrypt/local/lib/python2.7/site-packages/letsencrypt/client.py”, line 252, in obtain_certificate
return self.obtain_certificate_from_csr(domains, csr) + (key, csr)
File “/root/.local/share/letsencrypt/local/lib/python2.7/site-packages/letsencrypt/client.py”, line 225, in obtain_certificate_from_csr
authzr = self.auth_handler.get_authorizations(domains)
File “/root/.local/share/letsencrypt/local/lib/python2.7/site-packages/letsencrypt/auth_handler.py”, line 84, in get_authorizations
self._respond(cont_resp, dv_resp, best_effort)
File “/root/.local/share/letsencrypt/local/lib/python2.7/site-packages/letsencrypt/auth_handler.py”, line 142, in _respond
self._poll_challenges(chall_update, best_effort)
File “/root/.local/share/letsencrypt/local/lib/python2.7/site-packages/letsencrypt/auth_handler.py”, line 204, in _poll_challenges
raise errors.FailedChallenges(all_failed_achalls)
FailedChallenges: Failed authorization procedure. 65shelbycobra.com (tls-sni-01): urn:acme:error:unauthorized :: The client lacks sufficient authorization :: Correct zName not found for TLS SNI challenge. Found ‘65shelbycobra.com
2016-03-01 20:20:18,341:DEBUG:letsencrypt.cli:Exiting abnormally:
File “/root/.local/share/letsencrypt/bin/letsencrypt”, line 11, in
sys.exit(main())
File “/root/.local/share/letsencrypt/local/lib/python2.7/site-packages/letsencrypt/cli.py”, line 1986, in main
File “/root/.local/share/letsencrypt/local/lib/python2.7/site-packages/letsencrypt/cli.py”, line 1034, in renew
len(renew_failures), len(parse_failures)))
Error: 1 renew failure(s), 0 parse failure(s)
Try to run the same command which when you request the certificate for the first time. and check whether your DNS A records IP which belong to the '65shelbycobra' and your vps IP is matched
can I know what is your web server is it Apache ?
Apache on Ubuntu in the AWS cloud
DNS A record is OK
I am not sure what you mean by “vps IP matched”?
I am sorry for my English :3. I mean check wether VPS public ip is same as DNS A record ip
ok if you use apache I have an tutorial which shows how to use the lets encrypt Apache plugin
