Correct ca bundle to use
Then there are differences in ca-certificates.
This depends on how the trust store looks. When DST Root CA X3 is not present in the trust store, OpenSSL 1.0.2 can verify the chain (in real connections) without trusted-first. If DST Root CA X3 is in the trust store, verify-first is needed.
Thus the OpenSSL workarounds are accurate - either fix works. Usually it's easier to remove DST Root CA X3 than enabling trusted-first.
openssl verify somehow behaves slightly differently. I have skimmed through the code but haven't seen an obvious reason why it's different.
Now for my worst case scenario:
openssl version
OpenSSL 1.0.1f 6 Jan 2014
ca-certificates/trusty-updates,now 20170717~14.04.2 all [installed]
# echo | openssl s_client -connect helloworld.letsencrypt.org:443 -servername helloworld.letsencrypt.org | head
verify error:num=20:unable to get local issuer certificate
verify return:0
DONE
CONNECTED(00000003)
Certificate chain
 0 s:/CN=helloworld.letsencrypt.org
   i:/C=US/O=Let's Encrypt/CN=R3
 1 s:/C=US/O=Let's Encrypt/CN=R3
   i:/C=US/O=Internet Security Research Group/CN=ISRG Root X1
 2 s:/C=US/O=Internet Security Research Group/CN=ISRG Root X1
Yes, the client-side workarounds all only work for OpenSSL 1.0.2. OpenSSL 1.0.1 neither supports trusted-first, nor the remove-the-old-root workaround.
On the RHEL 6 thread, users have worked to build OpenSSL 1.0.2 for CentOS/RHEL 6 to be able to apply the workarounds. Similar things could be done for other distros, as there's ABI compatibility between 1.0.1 and 1.0.2. It's usually just a matter of recompiling.
Ubuntu has shipped patches for most of their versions (they've also fixed GnuTLS). However because 14.04 is EOL, they did not patch that. 16.04 got backports though.
NB: IMAP uses 993 for SSL and SMTP uses 587 for SSL, all IMAP servers have been using SSL for a long time
This is what everyone including me use for IMAP and SMTP for Linux based mail which is dominant. dovecot is the standard mail daemon which works with linux.
Yep. Just ran sudo yum update ca-certificates and no longer need -trusted_first for the long chains
Actually, I was launching test EC2's fresh but lately just been stopping / starting for speed. So did not get the update described here:
I think something in that AWS notice is wrong. The LE ACME servers no longer use the long chain so this is no longer true - right?
Servers with the affected version of OpenSSL and the DST Root CA X3 certificate in their root store can't issue or renew Let's Encrypt certificates.
Regarding the remove-the-old-root workaround it at least works on Debian 8 (jessie) using OpenSSL 1.0.1t
Cheers,
sahsanu
That is the fix/change Cpanel is rolling out soon to move away from openssl verify https://forums.cpanel.net/threads/cpanel-33077-letsencrypt-transition-to-isrgs-root-important.673981/post-2880185
@FGasper ah same Felipe at cPanel?
I just verified this and this is indeed true.
This seems to be however because of special backports Debian has made to jessie (back when it was still supported). It is not the case on official upstream OpenSSL releases.
Of note, CentOS/CloudLinux 6’s default OpenSSL (1.0.1e-fips) also allows trusted-first verification.
